96 XJ. One of my top 2 e-fan support screws is missing from where it mounts on that top cross support. There's a small black C shaped piece of metal that's stamped to accept the screw. C piece goes onto the edge of the cross support and then the screw goes through the hole.
Anyone know how I can identify this part number where I can order it, of what this piece is called so I can just look for a universal one? I know I could just shove a screw through it but I'd rather get the right piece.
Go to your local O'reilly and ask for the Doorman catalog and match up the part; it takes a lot of page flipping or go to your local pick and pull. Sometimes fasteners like that are hard to find. That or use a stout zip-tie as I have done in the past.
OP seems to be describing the part he hasn't got - or is just the screw he's missing?
Don't assume both sides of the shroud are secured the same way, the inboard fitting on my '98 is the fir tree part of the the harness/overflow pipe clip.
The clip OP describes is the cheap nasty one for self-tappers, whereas the shroud's held on by M5(?) machine screws, the better clips actually incorporate a nut; I'd get a pack of those from a hardware store & change them all while I was at it.
Thinking about it, there's actually 3 types, the ones with an integral caged nut I was referring to are probably overkill &, in any event, hard to find & needlessly expensive.
The 3rd type have a threaded turret (instead of a single spiral for a self-tapper) which is actually the OE type (just been out to check my spare slam panel) - should be able to pick up a pack of, maybe, 1/2-doz for $1 or so at any auto parts store.
working with metric. dump out a box of tools. then get another box of tools. dump them out.
then see if you have the right one.
go to the tool store for more tools. repeat above...
Somebody already called it a clip nut. That is an accurate name. The do come in m6x1.0 which I believe is what you probably have. Not all of them are for self tappers. Parts stores or a really comprehensive hardware should have them.
Sorry if I confused the issue referring to self tappers (that type of "spire nut" is more common here) because I thought that's what OP was describing - 'til I checked my own.
Not sure, from memory, that they are M6 though, & M6 bolts generally have 10mm heads, which I why I thought they were M5's, as they have 8mm heads BUT Jeep do seem to have a thing about bolts with non-standard size heads (&, indeed, some nuts that are oversize across the flats.)
I initially described the metal piece as stamped and that wasn't accurate. Didn't find out it had all those threads to accept the screw until I took it out after my initial post. Sorry bout the confusion. Found a good set on Amazon that should be here Friday so all four of the top fasteners are getting replaced. 2 for the e-fan and 2 for the regular fan shroud.
in a pinch a couple years ago i used a twisted wire. still good..
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
