transmission problem - JeepForum.com
post #1 of 20 Old 09-30-2016, 05:23 PM Thread Starter
jim-m
Xj transmission problem
1995 jeep cherokee xj 4wd 4.0. trans shifts at very high rpms. check engine light working but not showing. replaced iac,tps, and trans output speed sensor. any suggestions. only about 101,000 mi. fluid ok.
jim-m is offline
post #2 of 20 Old 10-01-2016, 10:13 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Adjusted the kick down/throttle valve cable ? Considered a good used Transmission Control Unit from the junkyard ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
“The powers delegated by the proposed Constitution to the federal government are few and defined. Those which are to remain
in the State governments are numerous and indefinite.”
- James Madison
CJ7-Tim is offline
post #3 of 20 Old 10-02-2016, 08:05 PM Thread Starter
jim-m
jim-m
adjusted kick down no luck. will a half qt. of the wrong fluid affect shifting?
jim-m is offline
post #4 of 20 Old 10-03-2016, 05:47 AM
CJ7-Tim
CJ7-Tim's Avatar
1/2 qt shouldn't make any difference.
- Benjamin Franklin
- James Madison
CJ7-Tim is offline
post #5 of 20 Old 10-03-2016, 05:16 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Try this:
http://cruiser54.com/?p=58
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #6 of 20 Old 10-05-2016, 08:02 PM Thread Starter
jim-m
checked connectors cleaned and sprayed, no tcu inline fuse under dash.did vacuum test. had trans flushed w/ conditioner and new fluid. no luck. still no engine light warning,bulb is working. can't find a obd1 anywhere to check. any way to test tcu?
jim-m is offline
post #7 of 20 Old 10-06-2016, 04:27 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Have you checked the line pressure at the test port on the trannie? At wide open throttle should be 170-210 psi.
If it is not you have a faulty pump, a faulty valve or dirt.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 20 Old 10-06-2016, 06:39 AM
75SV1
Check voltage at the battery. Then check what voltage is going into the TCU. Also, check the brake light switch. They get corroded.
75SV1 is offline
post #9 of 20 Old 10-07-2016, 12:12 AM Thread Starter
jim-m
battery and alt volts fine. what does brake light switch contacts have to do with trans not shifting until high rpms are achieved ? shifts from 1st to 2nd about 3500 rpms. shifts into reverse or forward gear no problem. does not shift manually shifts great no clunks no slippage. no off road or towing.
jim-m is offline
post #10 of 20 Old 10-07-2016, 12:45 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Does not shift manually?
If you disconnect the TCU can you get it to move from gear to gear with the shifter? From memory I think it will go R, 1, 3 and 4 on the shifter. This is the first test in the FSM.
post #11 of 20 Old 10-07-2016, 06:31 AM
75SV1
I'd have to look as to what the brake light switch specifically affects. It is part of the loop in this system. Also, the selector switch on the passenger side of the trans. Blanking on what it is really called.
75SV1 is offline
post #12 of 20 Old 10-07-2016, 08:00 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Correct.
post #13 of 20 Old 10-07-2016, 08:55 AM
CCKen
CCKen's Avatar
A defective Brake Lamp Switch may prevent the trans from going into overdrive, not what the OP is seeing.
The selector switch on the passenger side of the trans is the Transmission Range Sensor, aka NSS.
CCKen is offline
post #14 of 20 Old 10-07-2016, 10:06 AM
CCKen
CCKen's Avatar
Is shifting from 1 to 2 your only problem? Or is there a problem going from 2 to 3 as well?
CCKen is offline
post #15 of 20 Old 10-07-2016, 10:38 AM
Timo_90xj
Timo_90xj's Avatar
"Not shifting manually" - we need more info on this. Does it not shift manually at all, and only shifts in "D" from 1st to 2nd at 3500rpms? Or shifts fine in "D", but in manual mode shifts from 1st to 2nd at higher rpms?
As was asked, is the only problem the 1-2 gearchanges, and 2-3 and 3-OD are fine? When/ how does it shift into lower gears in D? Can you manually select lower gears if tranny is in higher gear?
***Under construction***
Timo_90xj is offline
