transmission issues - JeepForum.com
post #1 of 3 Old 04-09-2017, 10:19 AM Thread Starter
H0lmes440
transmission issues
this is my issue....i have a 89 cherokee 4.0 AT i did a motor swap to a 4.0 inline 6 out of a 95 jeep wrangler, she starts and runs beautiful accept she wont go in drive 1st2nd no problem 3rd same good but in drive nothing she wont move i have to drop to 1st2nd and manually shift till 3rd put her in drive she goes but no power she wont even kick down a gear to gain speed....ive check fluid, linkage, drive line, torque converter, now keep in mind its a 89 transmission on a 95 block if that makes a difference
H0lmes440 is offline
post #2 of 3 Old 04-10-2017, 05:23 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The Cherokee AW-4 AT transmission is controlled by a separate computer controller. The symptoms suggest that the trans is fine, but that there is a wiring issue such as failed/damaged wires or wire plugs, something is unplugged, or the Transmission Control Unit computer is faulty.
Did you adjust the kickdown cable using the Service Manual instructions ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 3 Old 04-10-2017, 08:15 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Look here and make sure both of those plugs are connected.
http://cruiser54.com/?p=58
Also, if you missed hooking up the grounds at the dipstick tube stud, or it's heavily painted, that could cause issues.
http://cruiser54.com/?p=19
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
