Trans fluid flush - Page 2 - JeepForum.com
 8Likes
post #16 of 40 Old 10-29-2019, 09:34 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That's all fine and dandy for you, but not necessary for a new guy to go that extreme. Drain and fill works just fine even if you do it a time or two. Heck, you can SEE the condition of the fluid.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #17 of 40 Old 10-29-2019, 06:47 PM
Boojo35
1987 YJ Wrangler
I would like to add that the pretty red color of trans fluid is an additive that can wear out over time. Pretty red fluid is a great thing. Do not get me wrong. It indicates good maintenance and a trans that is most likely very healthy. Darker fluid can be the color additive just being worn out and does not necessarily mean the fluid is trashed. Do your changes more often if you have this condition to get it back to pretty red.
You have already changed your filter so you should be good to go if you have a solid trans that did not have excessive metal or debris in the pan. Another no go is fluid that smells like it has been on fire. Burnt stuff. No maintenance can overcome that. An easy way to continue to recycle and freshen your fluid is to periodically suck fluid up the dipstick tube and replenish. Rinse and repeat. Very easy to do but some fluid suckers are cost prohibitive also. I get that.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #18 of 40 Old 10-29-2019, 09:48 PM
Fourspeedman
Fourspeedman's Avatar
I agree with the cooling line flush. Mine had 150k and was pretty dirty. First I changed the filter and cleaned the pan then filled it. I disconnected the hose at the radiator and ran a hose into a big jug. I had someone run the engine while I filled the trans at the dipstick with fresh fluid. When it ran cherry red I had him shut it off. I would oil up that quick-connect and see if it will come apart. If it won't you can cut the line and later splice with a short barbed nipple and hose clamps. But you might as well fix it anyway.
Fourspeedman is offline
post #19 of 40 Old 10-31-2019, 09:28 AM
60 Hotch
There are some simple ways to do a trans service many are short cuts some are over done. The bottom line is take the time and do it right. Drain the pan change the filter. Use good quality filters like the Wix 58936 and ONLY use the correct fluid. The manufacturer specs ATF+4 transmission fluid. DO NOT use “universal” or Mercon Dextron III or any other fluid. Do not mix transmission fluid types. ATF+4 is formulated for these transmissions as well as other transmissions. If you want to separate the lines you can buy a quick connect release tool made by Lisle. #3700. Amazon for $7.82. I agree after you drain and change the filter you can drain the fluid again then refill. I’ve seen guys drop the pan remove the filter start the engine for like 3-4 seconds and pump out the rest of the fluid. That’s a crap shoot for an older unit with lots if milage. I wouldn’t recommend that. This is from over 40 professional years of experience. Just my 2 cents. BTY the only time you should mix fluids is if you’re stuck and you gotta get home!
Paul
60 Hotch is offline
post #20 of 40 Old 10-31-2019, 09:42 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The AW-4 has always been specified to use Dexron-III/Mercon. Some people have issues when using ATF+4, and some don't. Since Dex-III/Merc is inexpensive, specified in the Service Manual and the Owners Manual, and available everywhere, Dexron-III/Mercon is what should be used. Even my local grocery store always has 2 or 3 bottles of Dex-III/Merc.
Rusty quick disconnects like to break more than they like to disconnect.
When the people find that they can vote themselves money, that will herald the end of the Republic.
- Benjamin Franklin
The powers delegated by the proposed Constitution to the federal government are few and defined. Those which are to remain
in the State governments are numerous and indefinite.
- James Madison
CJ7-Tim is offline
post #21 of 40 Old 11-01-2019, 02:51 PM
Fourspeedman
I just looked at my cooler line connections. I have a brass threaded fitting that I just unscrewed and fitted a clear hose to. I believe the upper line is the return from the trans so that is the one you rig to run into a jug.
post #22 of 40 Old 11-01-2019, 07:18 PM
Camaro45th
I need to do this. I think Ill bring it to the mechanic for it, I have no idea if my XJ ever had it done. Im depending upon it for going to work, so i think its worth doing.
Camaro45th is online now
post #23 of 40 Old 11-06-2019, 08:01 AM
SmashDN
Pull the trans dip stick and check the condition of the fluid. Does it smell burnt and look brown or black?
If you don't know the history of your vehicle or know if maintenance has been done I recommend to everyone to go ahead and replace all the fluids. Cheap insurance and relatively easy things to do in a driveway. Then if you ever do run into an issue that warrants taking it to a mechanic you have dates and specs for the most recent fluid changes you can supply the mechanic.
Camaro45th likes this.
SmashDN is offline
post #24 of 40 Old 11-06-2019, 08:03 AM
SmashDN
He said he wanted to open it up and flush it all out. I told him how to do it.
SmashDN is offline
post #25 of 40 Old 11-07-2019, 02:22 PM
rotorgoat
The lines don't hold much fluid. The trans cooler (if you have one) holds more and you can drain that. You can buy a set of special tools to remove the lines. They are plastic and inexpensive at your local auto supply. I bought a set to replace a leaking line. They are easy to use. The other advice to just do a multiple trans fluid change is probably easiest an just as effective.
rotorgoat is offline
post #26 of 40 Old 11-07-2019, 03:25 PM
Camaro45th
What is the likelihood that the filter needed to be changed?
post #27 of 40 Old 11-08-2019, 03:58 PM
rotorgoat
If you don't know when the last time the filter was changed I'd recommend changing it and new fluid.
Here's a YouTube link to show you how if you want to do it yourself.
post #28 of 40 Old 11-08-2019, 05:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
NONE!!!!!
It was never intended to be a maintenance item. It's a frickin' metal screen.
ALL these transmissions require is drain and refill. The trans line flush is fun and all, until the lines don't go back together or leak afterwards cuz they're decades old.
Or, you can have a ton of fun getting that pan off which is part of the dipstick tube via a crusty old, as in decades, o-ring.
This trans was used in 5 ton dumptrucks in Japan and in Toyota Celica turbos for crying out loud.
If this trans was made by GM, Ford, or Chrysler, we wouldn't be driving these rigs now.
They'd all be in the junkyard like S-10 Blazers, Bronco IIs, and Dakotas of the same vintage.
Quit trying to treat this AW4 trans like the piece of **** it is not.
TheBoogieman likes this.
post #29 of 40 Old 11-08-2019, 05:56 PM
Camaro45th
NONE!!!!!
Tell me how you really feel.
SmashDN likes this.
post #30 of 40 Old 11-08-2019, 07:11 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
It's not about feelings....
It's about facts.
Forum members get advised to do things they don't need to do, spend money they might not have, experience frustration and loss of use of their Jeep. e
Drain and fill, drain and fill. Watch it come clean. Screen is never dirty anyway.
For the cost of a gallon of DEXRON and a drain plug washer, a trans funnel and a drain pan........
2oldjeeps and Camaro45th like this.
