track bar - JeepForum.com
Closed Thread
post #1 of 26 Old 01-14-2007, 02:25 PM Thread Starter
Joe Senn
Guest
track bar
i need to know if i need my treck bar??? its located in the front right before the axle assembly we just put the lift on and cant get the bar in if we do not need it we will not bother with it will there be any changes in handling or performance if i do not use it??? any help would be greatly appericiated.
Joe Senn is offline
post #2 of 26 Old 01-14-2007, 02:35 PM
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
lol your kidding right
Yes you need it, Ifyou lifted it you need a adj one.
Arcticcat843 is offline
post #3 of 26 Old 01-14-2007, 02:39 PM Thread Starter
Joe Senn
Guest
figured but didnt know thought maybee just maybee but nope thanks
Joe Senn is offline
post #4 of 26 Old 01-14-2007, 02:42 PM
Arcticcat843
dakuda is a god
1980 CJ5
how much did you lift?
There is a way to redrill the holes in the axle side mount
Or you can buy an adjustable one.
post #5 of 26 Old 01-14-2007, 02:48 PM Thread Starter
Joe Senn
Guest
roughly an inch and a half (home brewed lift with the cutting board spacers)
Joe Senn is offline
post #6 of 26 Old 01-14-2007, 02:50 PM
Arcticcat843
dakuda is a god
1980 CJ5
You dont have to really worry about geting a new one with only an 1.5 inch lift
you can still use the stock one, but you axle will not be centered under your jeep.
To get it to go in, get two people, one person get in startd it up and turns the wheel from side to side, the other person slides it in when it is alined right.
post #7 of 26 Old 01-14-2007, 02:52 PM Thread Starter
Joe Senn
Guest
thanks but does it need to be started its on jack stands and pretty rickety
Joe Senn is offline
post #8 of 26 Old 01-14-2007, 02:52 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Take it out and try to turn... watch what happens....
Then put your helmet back on.
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #9 of 26 Old 01-14-2007, 02:55 PM
XJIceQueen98
XJIceQueen98's Avatar
and this is why i love u... always the sensitive one...
to the op.. don't ever take ur helmet off.. u'll hurt urself...
Originally Posted by SirGCal
You are the Ice Queen, not the warm and fuzzy queen... At least you live up to your namesake.:laugh:
Originally Posted by BigWaylon
if you think you're "normal" just because a majority of the posters on jeepforum agree with you...then you REALLY have issues...:D :D
XJIceQueen98 is offline
post #10 of 26 Old 01-14-2007, 02:57 PM
Awshux
Cynical Bastard
Awshux's Avatar
Yes, a trackbar is necessary. It keeps your axle centered under your vehicle, and without it you'd have little control over your steering.
You live and learn. At any rate, you live.
-Douglas Adams
Awshux is offline
post #11 of 26 Old 01-14-2007, 03:00 PM
Arcticcat843
dakuda is a god
1980 CJ5
Put everything back together wheels and tires too, then start it up and put on the trac bar
post #12 of 26 Old 01-14-2007, 03:03 PM Thread Starter
Joe Senn
Guest
thanks alot guys
Joe Senn is offline
post #13 of 26 Old 01-14-2007, 03:06 PM
Arcticcat843
dakuda is a god
1980 CJ5
thanks alot guys
No problem, take some pictures when it is done and post them up
post #14 of 26 Old 01-14-2007, 03:34 PM
GreenDean
GreenDean's Avatar
Trash the track bar.
just use some bailing wire and ducttape.
GreenDean is offline
post #15 of 26 Old 01-14-2007, 03:36 PM
Arcticcat843
dakuda is a god
1980 CJ5
make sure it is camo duct tape, That if 100x stronger than the regular stufff
Closed Thread
jeep xj track bar 4wd hardware track bar y-townxj XJ Cherokee Technical Forum 4 10-21-2009 06:39 PM
Should I use an extended track-bar bracket with an adjustable track-bar? Magickman XJ Cherokee Technical Forum 10 08-23-2008 11:12 PM
dumb idiots: adjustable track bar/HD track bar mount writeup sharpie XJ Cherokee Technical Forum 11 05-06-2007 09:52 AM
command track VS. quadra track natedawg87317 XJ Cherokee Technical Forum 13 10-31-2006 10:04 AM
Track Bar Bracket/ OEM Track Bar ?? 3" Lift Mikepags XJ Cherokee Technical Forum 5 06-08-2006 04:22 PM
