Tail Light Question - JeepForum.com
post #1 of 29 Old 03-02-2020, 07:28 AM Thread Starter
kerian159
Tail Light Question
Need to replace the rear tail light housings and the research I've done indicates that there are only three bulbs in a '98 XJ, however I know for a fact that my jeep has four. Could anybody offer an explanation to this?
Tried searching but it only comes up with LED conversion info (which is something that i'll be doing in the future)
kerian159 is offline
post #2 of 29 Old 03-02-2020, 07:46 AM
Pinoy59
1997 XJ Cherokee
The running light and brake light are the same bulb, then the back up light and blinker. What could the 4th bulb be?
Sent from my SM-G975U using Tapatalk
NP242/skidplates/RC4.5"LA kit/33x12.5mudclaws/15x10rim/sliders&flares/trussed-locked8.8/winchbumper
Pinoy59 is offline
post #3 of 29 Old 03-02-2020, 07:51 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Are you located in Europe, or USA ? If USA, there are only three bulbs. Any 1997-2001 taillight you purchase on the Internet or at the junkyard will fit.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 29 Old 03-02-2020, 08:05 AM
Ralph77
I am going with the 4th bulb being the rear fog lights
Does your other one look like this?
Do you have a switch that looks like this?
Ralph77 is online now
post #5 of 29 Old 03-02-2020, 08:18 AM Thread Starter
kerian159
Rear fog is what I was thinking as well but I'm in the USA, I don't have that switch nor do I have the rear tail light housings that look like that
post #6 of 29 Old 03-02-2020, 08:23 AM
Ralph77
And you are sure you have 4 bulbs?
post #7 of 29 Old 03-02-2020, 08:32 AM Thread Starter
kerian159
Yes it has two bulbs in the top area, one in the middle and one at the bottom. I checked the build sheet and it was Shipped and Sold in Indiana
Attached is the Build sheet
Equipment Listing
VIN
Vehicle Description 1998 JEEP CHEROKEE SPORT UTILITY 4-DR
Monotone Paint
117 Amp Alternator
500 Amp Maintenance Free Battery
Power Front Disc/Rear Drum Brakes
Reclining Front Seats
Rear Fold w/Removable Cushion Seat
Traveling Inboard Seat Belt Buckle
Next Generation Front Air Bags**
Carpets - Floor and Cargo Area
Cargo Compartment Carpet
Cargo Tie Down Loops
Plastic Liftgate Trim Panel
Passenger Assist Handles
Lift Gate Assist Handle
Full Length Floor Console
4-Speed Automatic AW4 Transmission
Command-Trac Part Time 4WD System
Dana M30/181MM Front Axle
Corporate 8.25 Rear Axle
Tinted Windshield Glass
Front Door Tinted Glass
Rear View Day/Night Mirror
Deluxe Insulation Group
STANDARD EQUIPMENT
100 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
DK QUARTZ - "CHEROKEE" Badge
DK QUARTZ - "JEEP" Badge
DK QUARTZ - "4X4" DECAL
DK QUARTZ - "JEEP" DIM. GRAPHIC
BLACK - FENDER FLARES
Headlamps On Warning Chimes
Glove Box Lamp
Halogen Headlamps
CHMSL Lamp
Front Bumper Guards
Black Windshield Moldings
Rear Qtr Solid Window Insert
Belt Moldings
Body Color Drip Trough Molding
Black Door Handles
EVAP Control System
20 Gallon Fuel Tank
Stone White C/C
Power Steering
Normal Duty Suspension
Front Stabilizer Bar
Rear Stabilizer Bar
Compact Spare Tire
Inside Mounted Spare Tire
Upgraded OBD-II Connectors
Tethered Fuel Filler Cap
Build To U.S. Mkt. Specifications
GVW Rating - 4900#
U.S. Dealer Retail
Zone 41-Cincinatti
Indiana Ship to State Code
Indiana Sold to State Code
Prem Cloth Hi-Back Bucket Seats
Indigo/Linen
Light Group
Sport Decor Group (97-02-26)
Power Equipment Group
4.0L Engine(ERH)/4Sp Auto Trans(DGS
High Back Bucket Seats
Highline Door Trim Panel
Front & Rear Floor Mats
Spare Tire Cover
Cargo Compartment Cover
All 4-Speed Automatic Transmissions
Lock-Up Torque Converter
Floor Mount Automatic Shift Lever
3.55 Rear Axle Ratio
All Engines
4.0L I6 Power Tech Engine
Deep Tint Sunscreen Glass
Deep Tint Sunscreen Liftgate Glass
OPTIONAL EQUIPMENT
Rear Window Defroster
Sun Visors w/Illum Vanity Mirrors
Power Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Remote Keyless Entry
Air Conditioning
DO NOT USE - See JP, KA classes
Instrument Panel Black Bezel
Rear Window Wiper/Washer
Power Windows
Power Locks
LAPIS BLUE - "SPORT" FRONT FENDER
DK QUARTZ - "4.0L" DECAL
BLACK - MOLDING - BODYSIDE
Courtesy Lamps
Map/Dome Reading Lamps
Underhood Lamp
Cargo Compartment Lamp
Headlamp Off Time Delay
Black Front Bumper
Black Rear Bumper
Front License Plate Bracket
Black Grille
Roof Rack
Federal Emissions
Stone White Clear Coat
All Radio Equipped Vehicles
AM/FM Cassette Radio
4 Speakers
Fixed Long Mast Antenna
Leather Wrapped Steering Wheel
Tilt Steering Column
P225/75R15 Wrangler RT/S AT Tires
Goodyear Brand Tires
15X7.0 Full-Face Steel Wheels
All Steel Wheels
8 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
Customer Preferred Package 2TJ
Customer Preferred Package 26J
Customer Preferred Discount
post #8 of 29 Old 03-02-2020, 08:49 AM
Ralph77
Well the only thing I can come up with at the moment is that somebody replaced the US tail lights with European ones including the harnesses.
But thinking the bottom bulb never would come on. I am assuming that is where the rear fog light bulb is in that array.
post #9 of 29 Old 03-02-2020, 08:52 AM Thread Starter
kerian159
So when replacing it i'd just tuck that plug out of the way?
post #10 of 29 Old 03-02-2020, 08:59 AM
Ralph77
Be frank not a clue.
Can we see your other tail light?
Would like to see it with every thing working or blinking too.
This is really going to bug me.
I don't even know if you have enough room there to tuck it away.
I am thinking no.
Might have to either buy one from Europe, usually super expensive, or replace your harnesses.
https://www.ebay.co.uk/itm/JEEP-CHER...Condition=3000
Do you have any switches, wiring, relays that you can't account for?
Again this is really going to bug me.
post #11 of 29 Old 03-02-2020, 09:08 AM Thread Starter
kerian159
when I get home this afternoon i'll post more info with better pictures and video
post #12 of 29 Old 03-02-2020, 11:49 AM
RLE
RLE's Avatar
I am in Africa and have a 98 Export model, brought over here new by
the previous owner, that has the four bulbs. The ones on the bottom have
never lit up in the 18 years I've owned it. I did happen to drive behind
a 2000 XJ last year and it's lower lamps lit up when he braked, along with
the upper bulbs. I'd like to see about getting mine to work that way.
RLE is offline
post #13 of 29 Old 03-02-2020, 12:05 PM
Ralph77
What have checked already?
I have a rear fog light switch that I scored from England.
Since the symbol is reversed thought I would try and use just the togglepart with a regular fog light switch for rear lights.
I did not play with it much but noticed that it seemed to not click on and off like a regular fog light switch.
Kinda more like the rear wiper switch when you push it for the washer.
I bought it so long ago that I can not remember for sure. Plus maybe something is just wrong with the switch. LOL.
Doesn't matter cause I only want the toggle for the symbol.
post #14 of 29 Old 03-02-2020, 02:58 PM Thread Starter
kerian159
Ok got home and took some pics.
post #15 of 29 Old 03-02-2020, 03:02 PM
Ralph77
Well that is a factory lens.
Somebody Mickey Moused something.
That second one down should not be there IMO.
You have to take that tail light off an see the wiring behind it.
That close up of the busted tail light in the second shot made things more clear.
Really could not see that in the first shot of it.
Well now I can cause I know what to look for. LOL.
