Swaping PCM in 96 XJ - JeepForum.com
post #1 of 6 Old 07-02-2020, 01:27 PM Thread Starter
xjdavid12
Can I swap a PCM in 96 XJ without doing anything else. It is early OBD2 with no chipped key or SKIM module. It does have overhead console with immobiliser.
Sent from my SM-N960F using Tapatalk
xjdavid12 is offline
post #2 of 6 Old 07-02-2020, 02:33 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Yes.
The donor Cherokee must also be a 1996 with the same engine, and the same transmission.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 6 Old 07-02-2020, 02:35 PM Thread Starter
xjdavid12
So I don't need to also swap the immobiliser module in the overhead console.
post #4 of 6 Old 07-02-2020, 03:55 PM
CJ7-Tim
CJ7-Tim's Avatar
What is "immobiliser module " ?
SKIM was the only factory installed anti-theft option. The OHC should only contain the key-less entry module.
- Benjamin Franklin
CJ7-Tim is offline
post #5 of 6 Old 07-02-2020, 04:13 PM Thread Starter
xjdavid12
From the FSM
OVERHEAD MODULE
The Overhead Module operates the Remote Keyles
Entry and the Imobilizer system.
Power for the Overhead Module is supplied by circuit F1 from fuse 26 in the Power Distribution Center. Inputs to the overhead module include; door ajar
illumination sense, door lock and unlock request, and
horn relay control.
The Overhead Module controls systems based on
inputs broadcast on the CCD bus.
post #6 of 6 Old 07-03-2020, 10:19 AM
CJ7-Tim
CJ7-Tim's Avatar
You are located somewhere besides the USA ? AFAIK US spec XJ Cherokees never had an immobilizer.
Seen this ? >>
- Benjamin Franklin
CJ7-Tim is offline
