stuck in park - JeepForum.com
post #1 of 4 Old 04-20-2004, 10:27 PM Thread Starter
morpho
Unhappy stuck in park
Dear all,
I managed to drown my 98 jeep recently and killed the alternator which has since been refurbished and reinstalled. The problem has become a little more serious in that I now have power but my little beast won't start and I can't get it out of park. It just clicks merrily away, all lights come on the dash, click, click, with no interest in moving a piston whatsoever. Its stuck in park really well. Any suggestions?
Regards
Ian
morpho is offline
post #2 of 4 Old 04-20-2004, 10:39 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I would check your trans linkage for anything that would bind up the shifter cable. I would also check the brake lever safety cable and make sure that it is not disengaged. It's a small cable that runs to the shifter from the brake pedal that doesn't allow you to shift without the brake pressed.
You need to check the dist cap and your coil to make sure you're getting spark, but first and foremost have your battery checked out/recharged.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 4 Old 04-20-2004, 10:39 PM
90lerado
90lerado's Avatar
Originally Posted by morpho
Dear all,
Regards
Ian
hmm well seeing as you said you took your jeep swimmin and killed your alternator, if the engine wont turn over that leads me thinking that you may have hydrolocked your engine...some other people on here may be able to help you a lil more, only thing i can think of is to put a bar on the flywheel and try turning it slowly and see if the engine turns.
"Few men are killed by the bayonet, many are scared by it. Bayonets should be fixed when the fire fight starts"
- General George Patton Jr, "War as I knew it" 1947
Wife's/my vehicle: 06 Pontiac vibe awd
Hopefully a jeep sometime in the future
90lerado is offline
post #4 of 4 Old 04-21-2004, 09:01 PM Thread Starter
morpho
Red face
Thanks guys. She's a pretty tough old enging, after I drowned it I didn't try to run it...for long. However, my enging is fine, I had to swap out the starter motor and she got all happy again. Embarrassingly enough the reason I could get it out of park it seems was because the handle on the shifter had slipped up, very ordinary. She's all happy now, I took a fair bit or bark off and drained a bit of claret out of myself as well as draining the oil out of the engine but its all good.
morpho is offline
Worst Stuck Picture Thread Or Just Stuck Bigbadwolf54 XJ Cherokee Technical Forum 19 08-13-2010 05:04 AM
Wow what a night; A STUCK: Quad, Friends moms WJ, A stuck bulldozer, Wrecker, Dodge. Element96x XJ/MJ Cherokee Non-Technical Forum 35 12-12-2009 03:54 AM
Piz help!!! np 231 stuck in neutral trany also stuck (ax-15) help!!!!! GB2DOORXJ XJ Cherokee Technical Forum 0 02-06-2009 09:07 PM
'96 xj stuck in park? ridekj XJ Cherokee Technical Forum 1 09-14-2008 08:03 PM
rear hatch stuck...REALLY stuck! BigJpXJ XJ Cherokee Technical Forum 4 09-25-2005 12:47 AM
