Stock Radio/Speaker Trouble (not generic problem) - JeepForum.com
 3Likes
  • 1 Post By 2oldjeeps
  • 1 Post By Mudovermakeup
post #1 of 9 Old 02-15-2019, 12:16 PM Thread Starter
Hoagy
So here is the issue at hand. I'm currently working on some deferred maintenance problems and the drivers door speaker issue is one of the problems. In my case the positive (green) speaker wire was sheared off between the firewall and door, I've soldered in a new section of wire and I have conductivity between the speaker plug and the one behind the kickplate on both positive and negative wires. When I plug the speaker in sometimes it will work for a while but then the whole system shuts off like a fuse is blowing, sometimes it is "blown" right away when I turn the accessories back on after install, however I've checked every fuse and none are bad. Thinking it was a bad speaker I've put in a new working stock speaker from another jeep and that one turns the system off as well. By taking a cable off the battery and leaving it off for a long period of time (shortest I have found it to work is 3hrs) the radio will restart, with the speaker out.
Whats going on? Has anyone experienced this problem before or have any suggestions on where to turn next, thanks.
Hoagy is offline
post #2 of 9 Old 02-15-2019, 02:10 PM
SSellers
Have you replaced both speaker wires or just the one? Possible one is grounding. If Infinity system with amplifier under the rear seat....most amplifiers have a thermal and/or low voltage protection circuit that turns them off. Don't know if the stock one does.
Steiner
1998 XJ Classic driver
1998 XJ Sport spare parts supply
SSellers is offline
post #3 of 9 Old 02-15-2019, 06:02 PM Thread Starter
Hoagy
It's not the Infinity system and I've only replaced one of the wires. I did leave a section of the green wire in the door because it was taped to the other wire so that was my next place to check, see if that's shorting the system. Was kinda hoping that someone would have an answer before I pulled all the wires out through the door to inspect
Hoagy is offline
post #4 of 9 Old 02-16-2019, 09:21 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You need to pull the door wire harness and inspect for damaged wires and chafed insulation. Failure of the driver door and tailgate wire harness is very common. The symptoms described are typical if there is a short circuit causing 12 volts positive to enter the speaker wires.
CJ7-Tim is offline
post #5 of 9 Old 02-16-2019, 03:58 PM
2oldjeeps
you might unhook batt, check both speaker wires to ground. neither side +/- is grounded. look at wiring in haynes book. its good for that.
JWELK likes this.
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is online now
post #6 of 9 Old 02-18-2019, 06:20 AM
Mudovermakeup
I actually just went through this, traced every single wire , fixed the broken ones, upgraded my speakers and the same thing would happen, so I took the radio out and bench tested it and it turned out to be the radio as well as the broken wires in the front doors.
2oldjeeps likes this.
Mudovermakeup is offline
post #7 of 9 Old 02-19-2019, 08:18 AM Thread Starter
Hoagy
Just getting back to the radio today; u-joints came in so I moved on to something that didn't want to make me drive it into a lake. Pulled the wires from the door and so far i'm thinking break in the harness that I can't find didn't see anything from the door to firewall. Gonna run new wires direct and see if that does the trick thought for a sec that it was broken wires I left in the door harness (green/black & green/red) but I think saw those were for the nonexistent infinity system. I had the radio tested around two years ago and was told that all the channels were working, how would I bench test it myself???
Hoagy is offline
post #8 of 9 Old 02-19-2019, 08:19 AM Thread Starter
Hoagy
*Edit* It was tested four years ago.
Hoagy is offline
post #9 of 9 Old 02-21-2019, 07:17 AM
Mudovermakeup
I just took it out, and hooked it to a battery and the 4 replacement speakers, had and old antenna kicking around from a K-5 blazer and turned it on, worked until the heat sink thing on the radio got very hot then it just started crackling over the speakers and was dead. So I bought a JVC and stereo install kit and all is good. I traced all the wires and know where they go if you need help.
Hoagy likes this.
electrical issue , radio , speaker , xj
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
2018 Grand Cherokee WK2 Transmission Problems Jeebs WK2 Grand Cherokee Forum 27 09-18-2019 07:35 PM
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 448 05-28-2019 07:14 PM
Idle/throttle response problem found and fixed agericke2011 XJ Cherokee Technical Forum 0 07-23-2018 08:18 AM
Heavy Gauge Problem! Flying_LP ZJ Grand Cherokee Forum 9 06-24-2018 04:24 PM
