Stock 4.0 XJs with the Highest Highway RPMs? - JeepForum.com
 2Likes
  • 1 Post By tbburg
  • 1 Post By jjvw
post #1 of 9 Old 10-30-2018, 12:37 PM Thread Starter
jjvw
jjvw's Avatar
This question is to entertain an idea I have regarding axle gearing for the 4.0.
What factory transmission/tire size/axle gearing combo resulted in the highest highway rpms on a XJ with the 4.0?
For example, an early TJ Wrangler was available from the factory with this combination...
32rh / 29.5" / 3.73 = 3186rpm @ 75mph
Was there anything comparable with the XJ?
2003 Rubicon
2003 Rubicon
jjvw is online now
post #2 of 9 Old 11-01-2018, 10:24 PM
tbburg
To the best of my knowledge, no 4.0-era XJ was ever available without an overdrive transmission. I believe it's a .75 OD on the AW-4. I think you could special-order 4.10 gears. Smallest tire available was a 225-75-15, about 28.5" tall(actual measurement)
jjvw likes this.
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
post #3 of 9 Old 11-01-2018, 10:31 PM Thread Starter
jjvw
jjvw's Avatar
Thanks! That's the kind of info I am looking for.
AW4/28"/4.10 = 2767rpm @75mph
My calculations come from grimmjeeper.com, btw.
The reason behind this is to see what rpms Jeep was running the 4.0 at from the factory as a way to demonstrate that the 4.0 is not a low rpm engine. And that when we regear for larger tires, we should not be afraid of going low.
2003 Rubicon
TheBoogieman likes this.
2003 Rubicon
jjvw is online now
post #4 of 9 Old 11-01-2018, 10:38 PM
tbburg
But then of course, I think the 4.10s were an upgrade optioned with the "off-road package" and probably weren't offered with the 225 width tire in that configuration.
Unless, back in the day, they could be special ordered "stand alone" on an otherwise bone stock, base 4.0 XJ.
anyway, it would be a rare combination.
tbburg is offline
post #5 of 9 Old 11-02-2018, 03:25 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
2003 Rubicon
it is not a high revving engine for sure, not much beyond 4500rpm and not much comfort above 3,500rpm for cruising. In this respect i has a shorter stroke than its 258 ancestor, and is able to rev higher and faster to make it a more highway friendly SUV engine, but it is still nailed by being a straight 6 tractor engine at heart.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 9 Old 01-26-2020, 01:54 AM
Hamid
Hamid's Avatar
Yes it concerned me too RPM vs speed.
I always wanted to know what should be the correct RPM for like 75 MPH, in order to know weather your XJ has a healthy engine or not.
2000 Jeep Cherokee Classic. Built for export
432K Kilos.
Hamid is offline
post #7 of 9 Old 01-26-2020, 09:06 AM
Michaelj51
3.55s in my stock 2001xj. AW4. 225 75R15 All Terrain tires. Freeway cruising [60 to 70mph] always in the range of 1850 to 2200 depending on incline.
Michaelj51 is offline
post #8 of 9 Old 01-26-2020, 09:46 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
It was NEVER a tractor engine or anything of the sort.
https://en.wikipedia.org/wiki/AMC_straight-6_engine
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #9 of 9 Old 01-26-2020, 09:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The 4.0 equipped vehicles came with a 3.55 axle in auto trans and 3.07 in manual trans.
3.73 and 4.10s were used in the 86 and earlier XJs and MJs only.
If you're worried about being at too high an RPM on the freeway, don't be.
It was the Brirish that used tractor motors in their cars. Not AMC.
The 230 engine of Jeep's was used in racecars driven by Juan Fangio with triple Weber carbs. I'm sure he revved it a bit above "plow" mode.........
