speedo not working after sye install - JeepForum.com
post #1 of 7 Old 01-22-2011, 01:17 PM Thread Starter
ajamison
ajamison's Avatar
1991 MJ Comanche
i installed a crown sye in my 231 last weekend. the speedometer worked for about 30 miles, then quit working. i tried tightening the bolt that holds the speedo gear assembly in the tcase, no luck. any ideas?
Jamison
ajamison is offline
post #2 of 7 Old 01-22-2011, 01:58 PM
NinjaofDoom
1990 XJ Cherokee
It might have done what mine did and ate up the plastic gears.
There was the episode where I threw my shoe at the enemy, like this!.... my foots cold.
NinjaofDoom is offline
post #3 of 7 Old 01-22-2011, 02:39 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Did you make sure the housing was clocked correctly for the gear you have?
xjfever is offline
post #4 of 7 Old 01-22-2011, 02:54 PM Thread Starter
ajamison
ajamison's Avatar
1991 MJ Comanche
no i didn't even think to check for anything like that
Jamison
ajamison is offline
post #5 of 7 Old 01-22-2011, 02:57 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The speed sensor housing will go in a few different ways to be able to use different size gears. You need to know how many teeth are on your gear to set it correctly. http://jeepin.com/features/speedogear This link will show how to do it.
xjfever is offline
post #6 of 7 Old 01-22-2011, 03:49 PM Thread Starter
ajamison
ajamison's Avatar
1991 MJ Comanche
ahhh thanks a bunch for the link! ill have to check under the jeep and see if the gear housing is in the correct location
Jamison
ajamison is offline
post #7 of 7 Old 09-16-2020, 07:57 PM
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
This thread has not gone to waste. I just learned from it in September of 2019. My gear was clocked wrong after a t-case swap. Works perfectly now.
Experience. It's what you get when you don't get what you want.
A beaver without a pelt is like a peacock without feathers.
Memberships: California Association Of 4WD Clubs - Friends Of The Rubicon - The Blue Ribbon Coalition
K6CKR
Originally Posted by Grape Ape
How many times have we told you . DON"T DUMP THE BODIES CLOSE TO YOUR HOME!!
HVACman is offline
Rev counter and Speedo not working clanryan XJ Cherokee Technical Forum 2 08-30-2009 07:56 PM
speedo not working rescuejk XJ Cherokee Technical Forum 7 02-10-2009 11:05 PM
I've been researching but SPEEDO still not working. robmckim2 XJ Cherokee Technical Forum 6 10-19-2008 07:35 AM
Speedo guage not working nootch6969 XJ Cherokee Technical Forum 1 07-11-2007 11:27 AM
Speedo and Rev Counter not Working clanryan XJ Cherokee Technical Forum 1 05-13-2007 06:50 AM
