Softer ride for 1994 xj - JeepForum.com
 15Likes
post #1 of 48 Old 02-10-2020, 12:47 AM Thread Starter
Serokee
Hello
I know xj is not cadillac and cant be cadillac but what shocks you prefer to get the most softer ride that you can get?
Monroe?
Ex owner has installed kyb excel g shocks and i know those are pretty stiff even in normal passenger vehicle.
I drive mostly in highways and bumby roads so i dont need rock solid suspension.
I also looked front coil springs at rockauto. There is heavy duty and regular duty. Is heavy duty spring allways like that upper picture and regular like second picture? Just asking so i can look which ones i have now.
Is there some other vehicles smoother springs that i can fit to my cherokee?
Serokee is offline
post #2 of 48 Old 02-10-2020, 04:43 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
IMO the stock Cherokee suspension is too soft, so I doubt you need new coil springs. If you measure the suspension and the coil springs have not sagged, any they are still good. Shock absorber choice has the greatest effect upon the perceived ride quality, softer vs. firmer. I prefer DoetschTech DT3000 or BDS shocks.
HD vs. reg coil springs, is usually controlled by the thickness of the coil spring material, and how the coils are wound. The progressive rate coils in the first picture are designed to be softer as it first compresses on small bumps and to get firmer with more compression.
TheBoogieman likes this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 48 Old 02-10-2020, 06:13 AM
car6car
del
04 Grand (dead)
car6car is offline
post #4 of 48 Old 02-10-2020, 10:24 PM Thread Starter
Serokee
Im international buyer so rockauto is easiest and cheapest for me.
How about 2.5/2wd springs? Those are thinner. Compressed lenght is same but free lenght little less than 4.0/4wd springs.
This is my first jeep so i dont know what is normal ride feel but i need more softness 🙂
Serokee is offline
post #5 of 48 Old 02-11-2020, 04:38 AM
CJ7-Tim
CJ7-Tim's Avatar
I would start with better shocks, and then determine if new springs are necessary.
IMO shocks are probably the primary determination for the perceived quality of the ride. Some brands lift kit springs are firmer than others, but many shocks sold as suitable for an XJ Cherokee, are actually one-size-fits-none shocks that are actually meant for full sized trucks.
- Benjamin Franklin
CJ7-Tim is offline
post #6 of 48 Old 02-12-2020, 01:48 AM Thread Starter
Serokee
Yeah its maybe the easiest and cheapest way to start.
Serokee is offline
post #7 of 48 Old 02-12-2020, 04:34 PM
TheBoogieman
Coronavirus survivor!
TheBoogieman's Avatar
Having tried many different shocks like Zone, BDS, RC, RE, ProCrap, Skyjacker, Bilstein and others. I prefer my Rancho RS5000X shocks even over my much more expensive Rancho 9000XL adjustable ones. Around $180 for a full set. Shock choice is subjective.
p.s. My stock coils and leaf springs had zero sag after 20 years and 145,000 miles.
JWELK likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes. ***SOLD*** for Covid-19 pandemic rent money. :(
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #8 of 48 Old 02-12-2020, 08:50 PM
Michaelj51
Having tried many different shocks like Zone, BDS, RC, ProCrap, Skyjacker, Bilstein and others. I prefer my Rancho RS5000X shocks even over my much more expensive Rancho 9000XL adjustable ones. Around $180 for a full set. Shock choice is subjective.
19 years and 215000, my 2001 is still at 17.5" front and down to 16.5 rear, rear springs are a bit flat but not quite to sag yet. Last 70000 miles on Les Schwab "Mountain Ryder XT" shocks. I wonder who actually manufactures them for Les?
Michaelj51 is offline
post #9 of 48 Old 02-13-2020, 06:43 AM
rjbruzan
What do you have for tires and what pressure are they at. This plays a big role in the ride also.
Ron
Ross likes this.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #10 of 48 Old 02-13-2020, 07:14 AM
Ross
For ride quality I would start from the ground up, tires then shocks and if still having issue springs.
The first thing you need to do is what rjbruzan suggest and check your air pressure. Then the condition of your tires and then the load rating.
Fi your tires are bad, you ride will be bad. If your tires are stock probably 32 PSI is were you should be. I they are oversized probably less. Check the load rating on your tires. Cherokees are light, you want a "C" rated tire.
Then shocks, search and ask for recommendations.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is offline
post #11 of 48 Old 02-13-2020, 01:09 PM
soapy
Junior Member
soapy's Avatar
I went with a Rubicon Express super ride lift with new coils,leafs,shocks and a few other parts and have been pleased with the results.
soapy is offline
post #12 of 48 Old 02-14-2020, 09:30 AM Thread Starter
Serokee
sorry but those brands sounds like hd suspension or lifted vehicle suspension choices? Where are all normal brands?
I had ranchos on my 79 bronco and 93 explorer. Ride was very very stiff.
Serokee is offline
post #13 of 48 Old 02-14-2020, 09:32 AM Thread Starter
Serokee
I have 235/75/15 tyre sets, bf goodrich all terrain for summer and european stud tires for winter.
Tyre sets are ok, i had driven same brands on many american cars and same pressure.
Serokee is offline
post #14 of 48 Old 02-15-2020, 10:18 AM Thread Starter
Serokee
This old test gives also harsh ride for jeep
https://youtu.be/yaR_D49V6A0
Or is cherokee sport more stiffer model? I have limited.
Serokee is offline
post #15 of 48 Old 02-17-2020, 06:31 AM
Ross
Look at the load rating on the tires, not the brand or style.
As far as the shocks? The ones Boogie mentions would be considered normal to people here. If you want more normal go to the dealership and see if they sell as stock replacements.
Ross is offline
