Shipped Jeep to Europe - Now Has Vibration Issues - JeepForum.com
post #1 of 9 Old 02-17-2015, 07:42 AM Thread Starter
dpasta1
1997 XJ Cherokee
Hey Guys...hoping you can help me out with an issue I am having after relocating to Europe and deciding to bring the Jeep ('97 XJ) with me.
Prior to shipping, I had shims installed and new u-joints put in the driveshaft, to help reduce vibration (already have a SYE kit installed...lift is 3.5"). The Jeep was running like butter upon bringing it to port in the US.
However, after receiving the Jeep in Europe and hitting the highway, the vibration is absolutely terrible...kicking in at about 30mph. It is exactly the same vibration as before installing the SYE, yet even worse.
The Jeep was on the ship for roughly 1 1/2 months, but I am not sure what could have caused / what is causing the issue.
Any ideas? Thanks in advance!
dpasta1 is offline
post #2 of 9 Old 02-17-2015, 09:47 AM
1stockjeep
1993 XJ Cherokee
The only thing I can think of is rust in the u joints or a shim getting moved around.
1stockjeep is offline
post #3 of 9 Old 02-17-2015, 12:04 PM
RLE
RLE's Avatar
x2 ^
With all that rolling around in the north Atlantic winter, if the U-bolts
weren't as tight as they should be, the shims could have slipped. So,
check the angle position and retighten.
It is recommended to retighten u-bolts a week or two after a new install
when the leaves, axle and u-bolts have all settled into position.
RLE is offline
post #4 of 9 Old 02-17-2015, 01:44 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I'd also check to see if it looks like any tire balance weights are missing.
***Chris***
chris87xj is offline
post #5 of 9 Old 02-17-2015, 05:34 PM
squirrelrocket
The Jeep still might have sea legs from that long boat ride. A greasy pork chop and a cigarette oughta fix that. I'd say check what the above posts say about rusty U joints. That damp salty ocean air can get in the tiniest, most annoying places. We ran into rust issues constantly when I used to work on the ocean. Felt like I was greasing junk everyday...
squirrelrocket is offline
post #6 of 9 Old 02-18-2015, 06:21 PM
sAe23
1995 XJ Cherokee
Rotate tires to see if they are involved.
Remove rear drive shaft and drive in 4Hi to see if the drive shaft and or u-joints are involved.
Same for front drive shaft (but in 2WD )
sAe23 is offline
post #7 of 9 Old 02-26-2015, 07:04 AM Thread Starter
dpasta1
1997 XJ Cherokee
Thanks a lot for the help here guys.
Two more amateur questions for you. Anyone know of any good articles on here for installing u-bolts in the driveshaft? Likewise for shims?
I've never actually taken that type of thing on myself, so any help would be really useful.
dpasta1 is offline
post #8 of 9 Old 02-26-2015, 10:46 AM
sAe23
1995 XJ Cherokee
Youtube has lots of videos on each topic.
sAe23 is offline
post #9 of 9 Old 02-26-2015, 01:15 PM
RLE
RLE's Avatar
If you would like articles with pictures, here are a couple to look at for
replacing driveshaft U-joints and for driveshaft overhaul (TJ is similar to the XJ).
http://www.stu-offroad.com/axle/ujoint2/ujoint-1.htm
http://www.stu-offroad.com/axle/driv...iveshaft-1.htm
RLE is offline
driveshaft , vibration , vibration drive shaft
