Shifter stuck in park, button wont work - JeepForum.com
post #1 of 11 Old 10-18-2010, 06:43 AM Thread Starter
LeMansGuy
96 XJ... so everytime the jeep has been sitting for more than an hour, i have to fight the shifter button so i can get it out of park. the button on the side of the shifter gets stuck, and it will take up to 5 mins of messing with it before it pops in and i can shift it. once the shifter has freed up, i can move it in and out of park or any other gear without issue.... WTH is going on with this thing?
1994 RHD XJ, retired postal carrier - parts jeep
1996 XJ Country - custom intake, 2.5" exhaust w/ high flow cat and super 44
LeMansGuy is offline
post #2 of 11 Old 10-18-2010, 06:45 AM
lowicz96
1995 XJ Cherokee
do you press the brake pedal every time?
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #3 of 11 Old 10-18-2010, 07:03 AM Thread Starter
LeMansGuy
yes, brake pedal is pushed, my wife asked me the same thing, lol.
post #4 of 11 Old 10-19-2010, 12:33 PM Thread Starter
LeMansGuy
any ideas???
post #5 of 11 Old 10-19-2010, 01:25 PM
AZ Jeff
2014 JK Wrangler
Pull off the handle. See if the cable that is actuated by the button will work with the handle removed. If not, then pull the console and see if the lever that drops in the notch on the quadrant is connected to the other end of the cable.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 11 Old 10-19-2010, 01:28 PM
lowicz96
1995 XJ Cherokee
carefully with pulling the handle off, I punched myself in the face doing that once. They are on there good.
lowicz96 is offline
post #7 of 11 Old 10-19-2010, 01:53 PM Thread Starter
LeMansGuy
thanks guys, so the handle just pulls off? so as long as i dont try to beat my self up, it should pop off with some force?
post #8 of 11 Old 10-19-2010, 01:58 PM
donthelegend
Yep, the first time is always interesting though. After you take it off once, its much easier.
donthelegend is offline
post #9 of 11 Old 10-19-2010, 05:30 PM
keepishop
keepishop's Avatar
1989 XJ Cherokee
Seems easier with the shifter in the 1-2 position. X2 on the face punching. It hurts.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #10 of 11 Old 10-19-2010, 05:38 PM
XJohnnyC
XJohnnyC's Avatar
While pushing the button in, tap upward on the handle with a rubber mallet. You won't hurt yourself this way.
XJohnnyC is offline
post #11 of 11 Old 10-19-2010, 05:43 PM
keepishop
keepishop's Avatar
1989 XJ Cherokee
Pulling with all your might toward your chest is bad too, though it will avoid face injury.
Bleed or Quit.
button , shifter , stuck
XJ won't crank before steering wheel unlocks, and shifter slammed into park clarkvstewart XJ Cherokee Technical Forum 1 10-03-2008 10:33 AM
'96 xj stuck in park? ridekj XJ Cherokee Technical Forum 1 09-14-2008 08:03 PM
Wont start, wont crank, and blowers dont work. L20KEV XJ Cherokee Technical Forum 1 02-26-2008 09:16 AM
Can move shifter without pressing button? itasor XJ Cherokee Technical Forum 15 11-19-2006 05:52 AM
stuck in park morpho XJ Cherokee Technical Forum 3 04-21-2004 09:01 PM
