Scorpion roller rocker arms installation - JeepForum.com
 2Likes
  • 1 Post By MaskedMallard
  • 1 Post By tburger88
post #1 of 14 Old 09-14-2021, 06:45 AM Thread Starter
tburger88
Junior Member
tburger88's Avatar
I’m putting in 1.7:1 non adjustable roller rockers on my new Clearwater cylinder head and the instructions from scorpion suck. 2000 Jeep XJ 4.0L. What do I do with the steel channel parts - circled in the pic below?
tburger88 is offline
post #2 of 14 Old 09-14-2021, 09:58 AM
Saudade
1988 XJ Cherokee
Its a WJ but still has the same engine. Note the position of those plates at the 4:25 mark.
Saudade is offline
post #3 of 14 Old 09-14-2021, 04:43 PM Thread Starter
tburger88
Junior Member
tburger88's Avatar
awesome - thanks!
post #4 of 14 Old 09-15-2021, 05:43 AM
MaskedMallard
Xj
I started to do a little research on Aluminum rockers, & I found this.
Used on a daily driven engine with a stock valvetrain, the rockers will last approximately 20,000-30,000 miles with regular oil changes. Since you run your engines for 250,000-plus miles, you would end up replacing aluminum rockers quite often.
Can someone explain a bit more? I didn't realize these go fast goodies had a short life expectancy.
kerian159 likes this.
2001 BJC Orvis XJ Build -
MaskedMallard is offline
post #5 of 14 Old 09-15-2021, 02:58 PM
2oldjeeps
2oldjeeps's Avatar
ez to predict an ongoing story here
99wj, 150,000 miles
00xj ,189,000 miles
10hummer3,76,000 miles
98xj, 133,000 miles
2oldjeeps is offline
post #6 of 14 Old 09-17-2021, 04:42 AM Thread Starter
tburger88
Junior Member
tburger88's Avatar
wow that’s bad; I guess I’ll clean up and hold on to my stock rocker arms. 😳
post #7 of 14 Old 09-17-2021, 04:44 AM Thread Starter
tburger88
Junior Member
tburger88's Avatar
Done. They look good but I hope they last. That Lucas assembly lube looks really blue.
post #8 of 14 Old 09-17-2021, 04:52 AM Thread Starter
tburger88
Junior Member
tburger88's Avatar
If the above estimate was from Summit Racing, they later put out this retraction:
Department of correction
Last issue, we fielded a question from Bill Hunter concerning using aluminum roller rocker arms in a daily driven street motor. We advised him that the rockers would only last 20-30000 miles with an otherwise stock valve train.
Well we were wrong. On a daily driver with stock valve train, most roller rockers will much last longer. In fact crane cams warrenties there rockers to 100,000 miles. on racing engines with high valve spring pressure and or oil restrictors that limit upper engine oiling, rocker arm life can be considerably shorter.
We apologize for any confusion our origional answer may have caused.
post #9 of 14 Old 09-17-2021, 06:23 AM
kerian159
Just out of curiosity what do you gain by changing out to these over the stock rockers?
"Growing Older, but not Up"
kerian159 is offline
post #10 of 14 Old 09-17-2021, 01:02 PM Thread Starter
tburger88
Junior Member
tburger88's Avatar
installation is a little easier and a bit more power. I had to change over to new head when my old one cracked, otherwise I never would have bought roller rockers
post #11 of 14 Old 09-17-2021, 04:41 PM
MaskedMallard
Xj
Good to know. Thank You for digging that up & posting that correction.
post #12 of 14 Old 09-18-2021, 08:27 AM
Saudade
1988 XJ Cherokee
The roller rockers are lighter, stronger, and reduce friction. I think the stock rocker arm ratio is 1.6:1 so the longer arm gives a bit more lift like a mild cam.
As noted above, beneficial (even necessary) in high(er) output motor application. In a stock XJ, maybe not.
Saudade is offline
post #13 of 14 Old 09-22-2021, 10:58 PM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
A ticking bomb. On the positive, 4.0 is non interference. That should spare your valves and pistons.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
2020 RECOUNT
rep-tile is offline
post #14 of 14 Old 10-04-2021, 04:08 AM
mhjo
mhjo's Avatar
I have the 1.7 non adjustabe Scorpions in my engine and they work fine.
2000 Sport, K/N, 12 hole injectors, Viper Coil Mod, 62mm TB
mhjo is offline
