Rubber lines by rear axel/gas tank? - JeepForum.com
post #1 of 4 Old 10-16-2019, 01:45 AM Thread Starter
legendslayer
hey dudes, just finished throwing a 3 inch RC lift on my 2nd XJ but this time when i finished the rear i had two rubber lines dangling from the uni body right right where the fuel lines attach to the gas tank on the side, not by the fuel sender on top and i'm not sure where they go! One has a twist on black plastic/rubber cap and the others just a very long rubber line, very thin lines, 1/4 , 1/8 of inch thick lines. looks like a vacuum line that runs in the unibody up to the front on the driver side.
My 93 Xj country didn't have these if i recall? This XJ is a 2000 sport.
Lmk what you think or where they go
Before some idiot suggests it, these are not the fuel lines, no theyre not the lines that go to the fuel sender on top of the tank, nor are they transmission lines
if im wrong lmk that im an idiot.
legendslayer is offline
post #2 of 4 Old 10-16-2019, 07:06 AM
jtec
jtec's Avatar
2014 JK Wrangler
Check your rear diff vent tube - that plastic cap seams a clue; the other line IMPORTANT part of EVAP system, what is EVAP emission status, codes?
jtec is online now
post #3 of 4 Old 10-23-2019, 10:45 PM Thread Starter
legendslayer
Hey Just wanted to update this post, after alot head scratching i realized the old shocks were air shocks before i started the lift and my new ones are just regular ol' RC 3 inch shocks; So that's where the vacuum lines used to go!
An admin can close/lock this thread!
post #4 of 4 Old 10-26-2019, 10:34 PM
42MBGPW
1990 XJ Cherokee
BIG thumbs up to you legendslayer for returning to the thread and posting the end result.
I'm down to a flat head powered flat fender and a couple XJ's,,, something must be wrong with me~
42MBGPW is offline
