replacing heater hose - JeepForum.com
post #1 of 22 Old 09-15-2010, 03:03 PM Thread Starter
everhguevara
1997 XJ Cherokee
hi, is there anything special i need to know before replacing the upper heater hose,do i have to drain the radiator? how much coolant am i going to lose? thanks in advance.
revolver
everhguevara is offline
post #2 of 22 Old 09-15-2010, 03:19 PM
cornbrizzle
1992 XJ Cherokee
You don't have to drain rad, just have a bucket to catch the little fluid that will come out , If you still have the stock/oem hose clamps on there now I would replace with a quality worm drive hose clamp !!!
just my .02
Brizzle
Dont Tread On Me
www.highsprings.com
cornbrizzle is offline
post #3 of 22 Old 09-15-2010, 03:33 PM Thread Starter
everhguevara
1997 XJ Cherokee
thanks a lot corn
revolver
post #4 of 22 Old 09-15-2010, 05:06 PM
XJohnnyC
XJohnnyC's Avatar
The upper heater hose, from the firewall to the thermostat housing, is 11/16", which is not an easy size to find at a parts store.
You can use 5/8", which will be a little tight. Or you can use 3/4", which will be a little loose. But you can clamp it down so that it won't leak.
The other heater hose that goes to the water pump is 5/8".
XJohnnyC is offline
post #5 of 22 Old 09-16-2010, 11:23 AM
mhall02
Bought my hoses from rockauto.com, Gates factory molded kind, exact replacement, no worries about trying to get the right size (~$20 for both before shipping). I re-used the hose clamps, especially helped at the heater core. At the firewall it is kind of a pain to slip a socket on the screw type of clamp when the original squeeze type were much easier to put back on. Plus you don't have to worry about overtightening and mashing the heater core copper outlets.
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #6 of 22 Old 09-16-2010, 11:44 AM
cornbrizzle
1992 XJ Cherokee
Just need to use a nut diver to tighten , the oem one will rust and will cut into the hoses . You can reuse the old clamps if you want , I would reccomend the worm drive on all hoses. But thats just me .
Brizzle
Dont Tread On Me
www.highsprings.com
post #7 of 22 Old 09-16-2010, 11:39 PM
filluptrk
I agree with corn on the clamps. OEM uses them because they are fast in an assembly line, and give same torque no matter who is doing them. You will not ruin the heater outlets using normal tightening, just tighten till they feel snug, and retighten after a month or so. If you use factory clamps and they begin to weep, then you cannot retighten.
filluptrk is offline
post #8 of 22 Old 09-16-2010, 11:51 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
how do you remove the heater hose from the core? it has the stock pressed on clamps with no way to loosen anything.
1990JEEPXJ is offline
post #9 of 22 Old 09-17-2010, 02:09 PM
mhall02
Used the factory clamps last year and no leaking to date Again, you gotta be careful using those screw clamps on that soft copper core.
I usually toss them when replacing the radiator hoses, but that heater core hose clamp is a pain at the firewall, so I thought I would use what was on there and see how it went. So far so good.
Patriot Blue
mhall02 is offline
post #10 of 22 Old 09-17-2010, 03:54 PM
AZ Jeff
2014 JK Wrangler
The OEM clamps are spring loaded, not pressed on. Once the clamp is sprung open with pliers and slid off, the hose may need to be cut with a utility knife to remove it from the nipple of the heater core tube.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #11 of 22 Old 09-17-2010, 04:14 PM Thread Starter
everhguevara
1997 XJ Cherokee
just don't do what i did, when i was cutting the hose from the heater core i accidentally damage the little hose that goes into the firewall, didn't notice anything until i turned on my heater and the air was only coming out of the defroster.
revolver
post #12 of 22 Old 09-17-2010, 05:09 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
so the tube coming from the input to the coolant resevoir is spring loaded?
post #13 of 22 Old 09-18-2010, 09:11 AM
AZ Jeff
2014 JK Wrangler
That depends on the year of XJ in question. The closed system reservoirs will probably have spring type clamps as OEM. The open reservoirs will use either no clamp, a crimp type clamp, or a spring clamp, depending on year (and mood of Jeep during the production run).
AZ-Jeff
AZ Jeff is offline
post #14 of 22 Old 01-09-2011, 02:01 PM
lowufo
1988 XJ Cherokee
heater hose replacement 88 xj
questions : can I just replace the hoses and keep the metal Y pipes for the heater ? It looks like original factory hose's and the rubber portion is pressed onto the metal pipes where the heater valve is etc.. looks like 2 different size hose's too ?? also expsanion tank is leaking around the hose fittings.any easy fixes for the tank or do I need a new one
Thanks !!
lowufo is offline
post #15 of 22 Old 01-09-2011, 06:03 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Thanks !!
I replaced all the hoses on my '90--IIRC I got the full kit from TeamCherokee, which included a new metal "Y" for the heater control valve with separate hoses and clamps. It wasn't wicked cheap, though.
Michael
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
need help with heater hose routing around heater control valve jerry4570 XJ Cherokee Technical Forum 2 10-11-2009 11:35 AM
Heater Hose Help Ac1d XJ Cherokee Technical Forum 5 07-05-2009 07:32 PM
pre-heater hose? liamchops XJ Cherokee Technical Forum 3 02-06-2009 08:36 PM
vacum hose on heater? jeeptorino68 XJ Cherokee Technical Forum 1 05-18-2006 06:49 PM
Replacing P/S hose ddoffroad XJ Cherokee Technical Forum 4 10-30-2004 08:27 PM
