Renix cooling system upgrade? - JeepForum.com
post #1 of 8 Old 05-20-2011, 01:50 PM Thread Starter
Mr_Clickerson
1994 XJ Cherokee
I've got an overheating Renix XJ and looking to kill two birds with one stone. Rather than replacing the radiator with another closed one, and then replacing my leaking pressure bottle, I want to swap one in from a newer Cherokee with the cap on the radiator. I've found a few threads and articles around in the past, but for the life of me, can't find them now, and don't have time to look for it now.
So, question time... What all do I need. 1 or 2 row radiator? Will I need a different thermostat? Can I just run my heater core hoses straight from the engine to the core without the valving or what? Any help is greatly appreciated.
Originally Posted by Lamb of God
Whoever appeals to the law against his fellow man is either a fool or a coward; whoever cannot take care of himself without that law is both. For wounded man shall say to his assailant, "if I live, I will kill you- if I die, you are forgiven;" such as the rule of honor.
Mr_Clickerson is offline
post #2 of 8 Old 05-22-2011, 05:01 AM Thread Starter
Mr_Clickerson
1994 XJ Cherokee
Originally Posted by Saudade View Post
Thanks. More specific searches yielded me nothing.
post #3 of 8 Old 05-22-2011, 04:21 PM Thread Starter
Mr_Clickerson
1994 XJ Cherokee
No one?
post #4 of 8 Old 05-22-2011, 04:58 PM
djb383
I believe the easiest way to convert is by splicing a conventional rad cap adapter into the top rad hose and running a tube from the new rad to a bottom fill, non-pressurized overflow bottle.
djb383 is offline
post #5 of 8 Old 05-22-2011, 05:02 PM
Empty_Pockets
Add an inline fill to the top rad hose, and replace the heater hoses with regular ones that dont have the metal sections, or just cut the t-sections out and lenghten your heater hoses. Did this to my 90 and hasnt over heated since. Those plastic bottles really suck.
Or you could get the rad with the cap, and run the heater hoses straight to the heater core......also replace your t-stat while your doing this they are cheap enough.
97 xj bone stock 5 speed
Empty_Pockets is offline
post #6 of 8 Old 05-22-2011, 05:18 PM Thread Starter
Mr_Clickerson
1994 XJ Cherokee
Well, the thermostat was going to get replaced, but I wanted to know whether or not I should be getting a different temp, and whether or not the number of rows my radiator had would affect it. I am also planning on replacing the radiator considering the fact that its overheating and how DISGUSTING the coolant was this last winter (that sludged up my heater core something awful).
post #7 of 8 Old 05-22-2011, 05:46 PM
djb383
Closed or open system, 1, 2, 3 row rad or temp of t-stat will have nothing to do with the prevention of a cruded-up cooling system.....that's a maintenance issue (or rather lack of).
djb383 is offline
post #8 of 8 Old 05-22-2011, 06:19 PM
Saudade
1988 XJ Cherokee
http://lmgtfy.com/?q=cherokee+xj+radiator+swap
Saudade is offline
cooling , overheating , radiator , renix , upgrade
Renix system upgrade? Mywrangler94 XJ Cherokee Technical Forum 3 01-12-2011 11:38 AM
89 cooling system upgrade WAD357 XJ Cherokee Technical Forum 4 06-08-2009 09:34 AM
Cooling system upgrade. Ski01xj XJ Cherokee Technical Forum 6 04-13-2008 10:38 AM
XJ cooling system upgrade. EVERYONE needs Green Envy XJ XJ Cherokee Technical Forum 15 06-25-2007 05:30 PM
Renix Cooling System Question Blue XJ XJ Cherokee Technical Forum 2 12-05-2006 07:27 PM
