removing center console..how?? - JeepForum.com
post #1 of 8 Old 11-19-2006, 08:54 PM Thread Starter
iwishihad1
hey everybody
i started prepping for herc'ing the inside of my jeep last night, and got all the seats out, and all the carpet, but cant get the center console out for nothing. i opened the "top" part of the console, removed 2 bolts there, pulled out the cover where the gear selector is, and removed 2 bolts there, and then up towards the dash there was just 2 clips. with everything removed still nothing wants to budge..what am i missing???
thanks
iwishihad1 is offline
post #2 of 8 Old 11-19-2006, 09:05 PM
TheWombaT
Guest
What year? From the sound of it though you're talking about x-96 not 97-01. Did you check under the 4wd selector
TheWombaT is offline
post #3 of 8 Old 11-20-2006, 06:14 PM Thread Starter
iwishihad1
its a 95. i havn't been able to get the black middle part out yet, which is in the middle of all the whole console..thats kind of confusing but somebody will know hopefully
post #4 of 8 Old 11-21-2006, 11:43 AM
basso4735
basso4735's Avatar
1997 XJ Cherokee
bump since i will be removing mine in my 96 so i could use any help.
- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline
post #5 of 8 Old 11-21-2006, 11:48 AM
Timo_90xj
Timo_90xj's Avatar
Uumh.. if I remember correctly, you need to remove both gear selector and 4wd selector plates, there are screws under that. There are also some screws under the center console box, you have to remove the inside of it.. I think.. removed mine last summer, there really wasn't too many screws holdinging it in place.
It might need some wiggling to be able to remove it with the e- brake handle on, but its doable. You do need to remove the gear selector T- handle though..
***Under construction***
Timo_90xj is offline
post #6 of 8 Old 11-21-2006, 12:01 PM
sc0872
yes there is screws you have to take out from both locations of shifters, I just had to take mine out.
sc0872 is offline
post #7 of 8 Old 11-21-2006, 01:26 PM
TheWombaT
Guest
Im not sure if this will help.
The "middle black part" is held into the other part by snaps. I don't know if this NEEDS to be snapped off in order for you to remove it, all I know is it made my removal 100x easier (to clear manual trans shifter).
Anyway I also found that removing the black part will break the snaps, rendering the add-on cup holder useless because it's not held in the same.
GG!
post #8 of 8 Old 11-21-2006, 02:36 PM
JeepFreak91
GG!
when i took mine off on my 1994 auto I didnt have any snaps, only screws to remove it all except for the auto selecter panel and the 4wd selector panel
JeepFreak91 is offline
Removing the center console on a 98? Boognish015 XJ Cherokee Technical Forum 4 01-07-2008 03:07 PM
Removing the center console. Ski01xj XJ Cherokee Technical Forum 2 11-04-2007 03:07 PM
Removing the center console on a 99: How? midfat XJ Cherokee Technical Forum 5 08-28-2007 10:40 AM
Pulling interior... removing center console? XJ4oh XJ Cherokee Technical Forum 5 01-15-2007 10:52 PM
'97-'99 Center Console in_burrito XJ Cherokee Technical Forum 1 05-03-2005 12:31 PM
