Removing the center console on a 99: How? - JeepForum.com
post #1 of 6 Old 08-28-2007, 10:10 AM Thread Starter
midfat
midfat's Avatar
I need to yank the center console out of my 99 Cherokee. Getting to the screws is no problem. My question is: Do I need to pull the shift knob (T knob, auto trans) off to get the console out? If so, what's the trick? I was looking at it and I can't figure it out.
Thanks,
Jim
midfat is offline
post #2 of 6 Old 08-28-2007, 10:14 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Pull the shifter handle straight up to get it off. Of shift the trans in 1/2, crawl into the back seat and reach over and yank the sucker straight back to pop it off.
I would assume the mount is similar to the old ones. Pop the shifter bezel off and look for mount points there. Pop the 4wd selector off as well and make sure there are none there.
From there, remove the center console door and the center console to check for mounts under it.
Once loose, feel for mounts up under the dash, or eye ball it and remove those as well.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 6 Old 08-28-2007, 10:29 AM Thread Starter
midfat
midfat's Avatar
Do I need to worry about yanking the shift release cable out of the T knob? That'd be my biggest fear.
midfat is offline
post #4 of 6 Old 08-28-2007, 10:32 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
No. Once you have it off, you can see that the shifter handle just has a botton that pushes down when you push the side botton in. On the end of the shifter is a small plastic nub that gets pushed down and disengages the shifte handle lock on the selector.
93 Sport
Specs in Profile.
balloo93 is offline
post #5 of 6 Old 08-28-2007, 10:34 AM Thread Starter
midfat
midfat's Avatar
once again, the Great Balloo93 hold the answers. Thanks. Exactly what I needed to know.
midfat is offline
post #6 of 6 Old 08-28-2007, 10:40 AM
crumb
Also, both the plates that the shifters come through just pop off and that makes it easy to get the console over the shifters.
And I think there is a screw under one of them.
My
1999 Cherokee Sport
4.5" RE Superflex Lift
crumb is offline
Removing the center console on a 98? Boognish015 XJ Cherokee Technical Forum 4 01-07-2008 03:07 PM
Removing the center console. Ski01xj XJ Cherokee Technical Forum 2 11-04-2007 03:07 PM
Pulling interior... removing center console? XJ4oh XJ Cherokee Technical Forum 5 01-15-2007 10:52 PM
removing center console..how?? iwishihad1 XJ Cherokee Technical Forum 7 11-21-2006 02:36 PM
'97-'99 Center Console in_burrito XJ Cherokee Technical Forum 1 05-03-2005 12:31 PM
