Rebuilt 1988 XJ engine won’t start - Page 2 - JeepForum.com
post #16 of 22 Old 04-17-2020, 06:54 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
CRUISER'S MOSTLY RENIX TIPS
DISTRIBUTOR INDEXING
OCTOBER 30, 2015 SALAD 52 COMMENTS
Firing Order
Renix dizzy indexing
Remove the distributor cap and cut a “window” into the side of the distributor cap at the #1 spark plug wire post . The “window” should be large enough to allow easy visual inspection of the position of the distributor rotor at the #1 spark plug wire post. Reinstall the distributor cap.
Use Tip 12 first to guarantee you’re on #1 TDC.
Install a ¾” wrench or socket onto the vibration damper retaining bolt. Rotate the engine in a clockwise direction until the #1 cylinder is at top dead center. Align the timing mark on the vibration damper with the “0” degree mark on the front cover timing scale. The tip of the distributor rotor should be near the #1 spark plug wire post.
Disconnect the distributor electrical connection. Remove the distributor holddown clamp, holddown bolt and distributor. Remove the distributor cap and rotor.
Place the distributor housing upside down in a soft jaw vise. Scribe a line 1/2 inch from the end of the distributor locating tab. Cut the distributor locating tab at the scribed line with a saw.
Remove any burrs and metal filings from the distributor. Reinstall rotor.
If necessary, using a flat blade screwdriver, turn the oil pump gear drive shaft until the slot is slightly past the 11 o’clock position. The oil pump gear drive shaft is accessible through the distributor mounting bore in the engine block. A little tip here. Rather than use a dizzy gasket, use an o ring instead. NAPA #727-2024.Dizzy o ring
Visually align the modified locating tab area of the distributor housing with the holddown clamp bolt hole.
Turn the rotor to the 4 o’clock position.Dizzy tab cuts
Lower the distributor into the engine block until it seats. The rotor should now be very close to the 5 o’clock position.
Reinstall the distributor cap with the cutout “window”. Rotate the distributor housing until the trailing edge of the distributor rotor tip is just departing from the #1 spark plug wire post terminal .
Reinstall the distributor holddown clamp and bolt.. Reinspect the position of the rotor to the #1 spark plug wire post to insure that it has not moved.
Install the new distributor cap, reconnect the distributor electrical connections.
HERE’S WHY DISTRIBUTOR INDEXING IS SO IMPORTANT:
Distributor indexing explained:
For clarification though, that’s not a cam sensor inside the Renix dizzy. It’s there to fire the injectors sequentially with the firing order. You’ll never notice if it went bad because the ECU will try to “guess” where it is and does a heck of a job at it.
As for the “timing”, it is controlled by the ECU. Ever notice how wide the tip of the rotor is? Try and wrap your head around this:
When the ECU yells “Fire” to the ignition control module, where is the rotor in relationship to the dizzy terminal? Not to the terminal yet? Past the terminal too far?
What happens to the spark/secondary ignition strength when it has to jump the Grand Canyon in comparison to shooting from a rotor tip? Poor ignition performance, bucking, jerking, longer crank times.
The factory was aware of this and issued a Technical Service Bulletin on it. This Tip, #13, is a condensed version of that factory TSB. You wouldn’t believe how many we found out of whack when I worked at the dealership. Yours is probably messed up also. RARELY did we find one set accurately.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #17 of 22 Old 04-17-2020, 06:55 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's an actual link to the above post, with photos.
The CPS generates it's own signal that goes TO the ECU BTW.
http://cruiser54.com/?p=68
post #18 of 22 Old 04-17-2020, 06:56 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Did you get that group of ground wires attached at the engine dipstick tube? Clean and shiny?
post #19 of 22 Old 04-17-2020, 07:27 PM Thread Starter
Chevelle001
Thank you all for your comment and help. Today I was finally able to turn on my Jeep. It ended up being the distributor. I removed it and repositioned it and it worked. It sounds great, thank you all. 👍👍👍👍😄&#x1f 604;😄
Chevelle001 is offline
post #20 of 22 Old 04-18-2020, 07:00 PM Thread Starter
Chevelle001
Ok so I broke the engine in today, at 2000 RPM for 30 min and everything went OK until I notice that the transmission had no transmission fluid. Will that damage the transmission??? It’s doesn’t want to move
post #21 of 22 Old 04-22-2020, 06:35 PM
Fourspeedman
Fourspeedman's Avatar
Maybe the converter. Did you put the oil in?
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is offline
post #22 of 22 Old 04-22-2020, 08:14 PM
riderboy1961
riderboy1961's Avatar
Not necessarily...
You mean the fluid doesn't show on the transmission dip stick correct?
You prolly just need to fill the transmission fluid up.
*Example (sort of): I picked up an 07 Dodge Durango a few years ago from a yard to drive home. I checked the transmission fluid about 20 miles down the road, there was None showing on the dip stick. It ended up needing 2.75 quarts of trans fluid to get it to the full / hash marks on the dip stick, it had driven just fine before checking it. It ran and shifted normally After I filled to the hash marks. It had No Noticeable Transmission Damage/ Shift Problems while I drove it around town for that next week. (I was surprised that it had shifted normally being 2.75 quarts low on transmission fluid)
Thank You,
Bo
riderboy1961 is offline
