Rear Springs Lift - JeepForum.com
 3Likes
post #1 of 22 Old 08-06-2020, 03:00 PM Thread Starter
grwgoldpro
grwgoldpro's Avatar
Rear Springs Lift
I just put Crown heavy duty front coil springs in my 99 Cherokee 4x4 and now the front is 1.5” higher in the front than the rear. What is the best and cheapest way to raise the leaf springs up in the rear 1.5 inches and a quality install.
Gary
grwgoldpro is offline
post #2 of 22 Old 08-06-2020, 03:02 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Some version of an add-a-leaf.
Read this > https://www.jeepforum.com/forum/f11/...vs-rls-640285/
grwgoldpro likes this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 22 Old 08-06-2020, 03:10 PM
Pinoy59
Pinoy59's Avatar
1935 CJ2A
The easiest way without changing the spring rate would be some longer shackles. If you want stiffer springs then use an add a leaf. I am not a fan of blocks.
You could also do shackle relocation brackets that will give you more articulation if that is what you are looking for.
Sent from my SM-G975U using Tapatalk
NP242/skidplates/RC4.5"LA kit/33x12.5mudclaws/15x10rim/sliders&flares/trussed-locked8.8/winchbumper
Pinoy59 is offline
post #4 of 22 Old 08-06-2020, 03:18 PM
CJ7-Tim
CJ7-Tim's Avatar
Like I related in the linked thread about low cost options to add lift, extended shackles will ruin a stock XJ leaf spring pack, and a full length AAL is slightly firmer than stock, but is not objectionably firm. Using a stock XJ Cherokee leaf pack for a donor add-a-leaf results in practically the same spring rate.
- Benjamin Franklin
CJ7-Tim is offline
post #5 of 22 Old 08-08-2020, 03:27 AM Thread Starter
grwgoldpro
grwgoldpro's Avatar
I’m going with Dorman or Crown heavy duty rear leaf springs probably Crown. For the money I think that’s best per the posts here. Thanks again.
Gary
post #6 of 22 Old 08-16-2020, 06:17 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Post your results when you're done.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #7 of 22 Old 08-16-2020, 12:44 PM Thread Starter
grwgoldpro
grwgoldpro's Avatar
I bought the Crown 4886186AB HD Leaf Springs. So confusing with different part numbers and letter designations (AA, AB, Etc.) and arch height. Some say these are equivalent to UpCountry some say not. Anyway those are going on my ole 99 next week. I think they will be a little harsh without load but that’s ok. I have the same brand Crown HD coil springs on the front and I like them. Time will tell.
Gary
post #8 of 22 Old 08-16-2020, 02:59 PM
bornfrustrated
Add a leaf will change the spring rate from what is currently is. Longer shackles will keep the same spring rate.
bornfrustrated is offline
post #9 of 22 Old 08-17-2020, 11:33 PM
steelo2525
https://www.google.com/url?sa=t&sour...suY9xEvU5LMMe9
Look at something like these
Sent from my Nokia 7.2 using Tapatalk
steelo2525 is offline
post #10 of 22 Old 08-18-2020, 04:47 AM
CJ7-Tim
CJ7-Tim's Avatar
Like I related in this thread about low cost options to add lift: https://www.jeepforum.com/forum/f11/c...vs-rls-640285/
  • short add-a-leaf are very stiff and are not a good lift option
  • long full length add-a-leaf only slightly increase the spring rate
  • extended shackles on stock leaf springs have a substantial risk of ruining the leaf springs.
- Benjamin Franklin
CJ7-Tim is offline
post #11 of 22 Old 08-19-2020, 04:52 PM Thread Starter
grwgoldpro
grwgoldpro's Avatar
Had my order in for a week and today Morris Tells me out of stock with no ETA. Crown Springs 4886186AB and Dorman 929-301 for Cherokee are imposible to find right now. I did find OMIX-ADA HD and cheaper. Anybody have experience with OMIX-ADA?
Gary
post #12 of 22 Old 08-19-2020, 05:21 PM
Pinoy59
Pinoy59's Avatar
1935 CJ2A
Chinese, but i think they have gotten better over the years.
Pinoy59 is offline
post #13 of 22 Old 08-20-2020, 11:52 AM
Coyotejunki
Coyotejunki's Avatar
I ordered a set and only one arrived, No one knows where the other one is. So I cancelled it and ordered one from Car parts .com
Coyotejunki is offline
post #14 of 22 Old 08-20-2020, 12:13 PM
Coyotejunki
[QUOTE=CJ7-Tim;41041397] extended shackles will ruin a stock XJ leaf spring pack, and a full length AAL is slightly firmer than stock,/QUOTE]
I don't understand how this will happen, please explain, I was going to put on 1"-2" shackle extensions
post #15 of 22 Old 08-20-2020, 12:15 PM
Pinoy59
Pinoy59's Avatar
1935 CJ2A
[quote=Coyotejunki;41052865]
Since they are longer they allow the spring to flex more. Bend the leafs too far, too often and they lose their spring. So eventually they will sag and possibly invert.
Pinoy59 is offline
