Rear Main Seal Leak, Front Diff Seal Leak, Valve cover leak. - Page 3 - JeepForum.com
post #31 of 49 Old 11-12-2009, 03:09 PM
Rollin
Rollin's Avatar
Originally Posted by willcherokeexj View Post
Would it be wise to add more gear oil for now? I can't get it done and I need to drive it...
And does mixing different motor oils cause a problem? as long as they are the same kind?
You can mix any kind of dino motor oil with any other kind of dino motor oil. You can also keep adding oil to the diff and it will be fine. I personally like the mud method. I used to have leaks on both my steering box and my pinion just like yours. Both seemed to have been solved with a good dose of mud from wheeling.
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #32 of 49 Old 11-12-2009, 04:20 PM Thread Starter
willcherokeexj
2014 JK Wrangler
So how do you tell how much oils in it?
Mines way past the safe thing
2000 XJ - traded in
2014 JK - Willy's Wheeler Edition
willcherokeexj is offline
post #33 of 49 Old 11-12-2009, 05:12 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Safe thing on what?
If the diff, just make sure it has oil level with the fill plug when you remove it.
If the motor, do not fill past the full mark on the dipstick.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #34 of 49 Old 11-12-2009, 05:22 PM
LKrux
hes talking about the dip stick.
thats probably a lil to much but i cant tell you without any pics...just quit worring about it so much.but do keep an eye on it.
you can be in college and work on your car..just find a write up for replacing the seals, or find a write up about installing a locker or regearing and see how the axle comes apart and how they install the seals. i mean it should be fairly simple.the write ups are step by step.
id just go buy tools and fix it.find a write up.
LKrux is offline
post #35 of 49 Old 11-12-2009, 08:09 PM Thread Starter
willcherokeexj
2014 JK Wrangler
Oh found another minor issue.
T-case is leaking
It looks like its coming from some sort of seal. Like where the left half connects to the right.
Not worried,cause I can just undo the plug and put more fluid in... Already went to autozone grabbed some castrol ATF(dexron III) and a little spout.(All I have to do is undo the bolt on the drivers side right? the hex bolt?) The leak from the t case doesn't bother me just gota refill every few months.
Diff is getting fixed tomorrow. Its leaking from the yoke(on the tcase) and from the diff. 70 bucks And saves me the mess.
Sunday I'm cleaning most of the oil off and calling it done. Will do the rear main in a few months.
2000 XJ - traded in
post #36 of 49 Old 11-12-2009, 10:20 PM
phmaris
Hey I'm in Chicago suburbs and need to do the pinion seal on mine too. Lets get a party together and work on some Jeeps. I even have access to a full shop with Tools/Lift for $100 a day near Ottawa IL? Plus its close to the Cliffs insane all terrain park!
phmaris is offline
post #37 of 49 Old 11-13-2009, 05:15 PM Thread Starter
willcherokeexj
2014 JK Wrangler
Ok so I was out there for an hour looking for the right tool and stuff to add more fluid to the t case...
What tool to remove the fill plug? and whats the best way to add fluid?
Going to ACE hardware soon..
only place still open
2000 XJ - traded in
post #38 of 49 Old 11-13-2009, 07:42 PM
thnksno
I used a big crescent wrench because it's like a 1 3/4" bolt head... Getting fluid in is a bit of a trick, I bought a "pourer" that fits on quart containers. It allows you to shut off then open flow after tipping the container. It leaks a little bit, but for like $2.49 at autozone it gets the job done.
Put some RTV on the drain plug before putting back in, your t-case leak will probably disappear.
thnksno is offline
post #39 of 49 Old 11-13-2009, 09:43 PM
Beefcake7777
Beefcake7777's Avatar
man you have had so many offers from people to help you out in person and you just ignore them, personally i would jump at the oppurtunity to pay for pizza and help other jeepers work on my jeep. but hey thats jus me
"I live, I ride, I am.........CHEEP
Beefcake7777 is offline
post #40 of 49 Old 11-13-2009, 10:10 PM Thread Starter
willcherokeexj
2014 JK Wrangler
I'm open to having people help just never have time(school!)
2000 XJ - traded in
post #41 of 49 Old 11-13-2009, 10:37 PM
7urtle
7urtle's Avatar
2008 KK Liberty
doesnt look like were gona have a bad winter. just wait till winter break. if it aint nut freezin im still down
hit it with a hammer
-1UMF a really slow build. bruised and never left the street
WTB: rear bumper/tire carrier,31" tires,armor
7urtle is offline
post #42 of 49 Old 11-14-2009, 05:22 AM
Myjeepblows
Guest
seen worse.. !!
Myjeepblows is offline
post #43 of 49 Old 11-15-2009, 01:05 AM
Hussler
Hussler's Avatar
1992 XJ Cherokee
Originally Posted by Myjeepblows View Post
seen worse.. !!
what the **** kind of jeep do you drive? your tag 1996 FSJ Cherokee confuses and angers me
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #44 of 49 Old 12-03-2009, 04:54 PM
72combo
If the oil does not leak bad enough to drip on the driveway I say free oil spray, since it probably only leaks while driving or running. Just keep an eye on the levels and top up as necessary.
72combo is offline
post #45 of 49 Old 02-07-2010, 08:50 PM
autoposer
One thing to add here is that many of the 2000 XJs have the 2001 seal type. The 2001 version has less material and costs an extra $15 for a total of $35 at Napa.
autoposer is offline
Oil Leak . . Rear Main Seal? Efekt98XJ XJ Cherokee Technical Forum 10 03-26-2009 05:53 PM
rear main seal leak? badlands1 XJ Cherokee Technical Forum 11 12-24-2008 09:48 PM
rear main seal leak 70ssclone XJ Cherokee Technical Forum 8 11-23-2006 02:04 AM
Rear main seal leak!!! Dvs_Lance XJ Cherokee Technical Forum 6 03-10-2005 09:42 PM
oil leak above rear main seal??? sleddy5 XJ Cherokee Technical Forum 2 02-11-2005 12:42 PM
