Rear main leaking. Anything else to fix? - JeepForum.com
post #1 of 3 Old 01-04-2012, 01:33 AM Thread Starter
Chris223
Heres the deal my rear main is leaking and a friend of mine has a shop who will do repair in the next week or two. Any recomendations on seals?
Or anything else I should fix or check while its in the air?
I have a 00 4x4 4.o a/t has 136k on it. Any help would be great
Thanks.
Chris223 is offline
post #2 of 3 Old 01-04-2012, 05:17 AM
mbardeen
1995 XJ Cherokee
1) Are you sure it's the rear main? Many other potential leaks look the same. Check valve cover gasket, distributor gasket, and oil filter gasket prior..
2) Oil pump. They're cheap and if you've got the oil pan off, might as well do it.
mbardeen is offline
post #3 of 3 Old 01-04-2012, 02:28 PM Thread Starter
Chris223
Yes it is the main checked the others. Any preferance to oil pump?
Chris223 is offline
Rear main leaking? The Shadow XJ Cherokee Technical Forum 11 04-16-2010 10:55 AM
Rear main seal Leaking trevsbmw XJ Cherokee Technical Forum 5 09-16-2008 04:12 PM
I am leaking oil, but how do I know it the rear main seal? Waveridr85 XJ Cherokee Technical Forum 2 08-03-2007 04:17 PM
rear main seal leaking snow2004 XJ Cherokee Technical Forum 2 05-22-2006 02:15 PM
Replaced Rear Main in 4.0, Still Leaking!! Sabreman XJ Cherokee Technical Forum 6 01-31-2006 11:55 AM
