Rear Drum Brake Question - JeepForum.com
 1Likes
post #1 of 17 Old 05-10-2021, 06:23 AM Thread Starter
kerian159
I went to adjust my rear brakes this past weekend and the piece that holds the star from backing off the self-adjustment was not engaging correctly. I took the wheel off and looked inside and everything looked correct, but the only way I could get it to engage was to pull the cable that runs down to that piece and tighten it up a bit. Does this make any sense to any of you guys? If you have questions I'll try to describe things better (I didn't get any pictures).
"Growing Older, but not Up"
kerian159 is online now
post #2 of 17 Old 05-10-2021, 08:30 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I often find that cheap crappy Chinese drum brake hardware kits fit and function poorly. I would suspect that is the problem. Often the cable and spring assembly is too long or the star wheel arm is not the correct shape.
I either check/adjust the drum brakes every oil change, or pick up better quality drum brake hardware from the junkyard.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #3 of 17 Old 05-10-2021, 08:36 AM Thread Starter
kerian159
It appears that the cable is too long so I guess I'll be searching for a new brake kit (just replaced this last oct.)
post #4 of 17 Old 05-10-2021, 12:31 PM
UKXJ
1997 XJ Cherokee
Location: The Smoke, The English Riviera - or somewhere in between
I don't think that cable makes any difference. Last time I did the rear brakes they were both broken, so I discarded them as never known XJ (or any other) so-called "self adjusters" to work.
I like CJ-Tim's adjustment routine but it's too organised/disciplined for me - & I don't think they need doing that often. I just do mine for inspection each year, unless it becomes obvious the e-break's not holding as well as it might or the lever's coming up far too high.
kerian159 likes this.
UKXJ is offline
post #5 of 17 Old 05-12-2021, 08:16 PM
Wyo
Wyo's Avatar
I have had good luck with adjusters but I also use antisieze at all the contact points.
Wyo is offline
post #6 of 17 Old 05-13-2021, 05:52 AM Thread Starter
kerian159
The adjusters work, I'm just not getting the click part to lock into it correctly.
post #7 of 17 Old 05-15-2021, 06:28 AM
BaileyNB
1993 XJ Cherokee
Could always pull the disc brakes from a ZJ or Liberty (depending on axle) and upgrade. Then you don't have to worry about the adjuster at all other than the initial setup for the internal drum parking brake.
One day of work definitely beats out messing with drum brakes for the rest of the vehicle's life, at least if you ask me it is.
BaileyNB is offline
post #8 of 17 Old 05-15-2021, 09:44 AM
Wyo
Wyo's Avatar
Of all the things I have had problems with over the years the Drum brakes are not the issue that has been recurrent. on my XJ's. I mean I do check them when changing to winter studs, Maybe a clean and Move them around to check for binding, add a bit of antisieze where needed, but that is kinda it Until I need to turn and replace shoes every 80- 100K or so.
I live in the mountains and tend to run very heavy 99.9 % of the time with lots of stuff in the Jeep.
I didn't know this was a "Thing".
Wyo is offline
post #9 of 17 Old 05-15-2021, 09:54 AM
UKXJ
1997 XJ Cherokee
That's not strictly true, you'd still have to adjust them once a year pre-inspection (at least, we would).
That said, always wanted rear discs on the XJ's - 'til I did a rear brake overhaul on a WJ! Never again!!
UKXJ is offline
post #10 of 17 Old 05-15-2021, 01:00 PM
Fourspeedman
Fourspeedman's Avatar
I have never known self-adjusters to work right. If they did all you need to do is go backwards and hit the brakes hard several times until they tighten up. That "should" adjust them but never does. I remove the self adjusters on all my cars. I can tell the drums need adjusting when my hand brake travel gets excessive. Then I just raise up the rear and adjust them.
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is offline
post #11 of 17 Old 05-15-2021, 01:39 PM
Wyo
Wyo's Avatar
I dunno, Maybe it's because I pull the drums when I swap tires twice a year and check them and do minor clean, Maybe because I back down a hill everyday. Dunno, hasn't been my problem.
They seem to work fine for me.
Wyo is offline
post #12 of 17 Old 05-15-2021, 06:01 PM
CJ7-Tim
CJ7-Tim's Avatar
Between road salt ruining everything but the tires, and cheap Chinese brake parts kits, I just gave up and adjust the drum brakes as needed when changing oil and/or rotating tires. The only rust free Jeeps I see are new or brought in from elsewhere.
CJ7-Tim is offline
post #13 of 17 Old 05-16-2021, 04:00 PM
UKXJ
1997 XJ Cherokee
Never knew the self-adjustment was meant to work like that, but rather by use of the hand brake; which is why automatics nearly always fail inspection on hand brake - 'cos last time lever was pulled up was the previous year's inspection! Although I discarded the self-adjusters on my '97, when doing a complete overhaul, that was because the cables were broken but removing them almost as a matter pf principle just seems like an extra job that doesn't need doing. However, I'm totally in agreement about knowing when they need doing (if only they were all as easy as XJ's)
UKXJ is offline
post #14 of 17 Old 05-16-2021, 04:09 PM
UKXJ
1997 XJ Cherokee
Originally Posted by Wyo View Post
. . . Maybe because I back down a hill everyday. . . .
Now that's interesting, in light of Fourspeedman's explanation of how the self-adjusters are supposed to work.
UKXJ is offline
post #15 of 17 Old 05-16-2021, 08:54 PM
Wyo
Wyo's Avatar
I always knew that was how they worked, but I don't jam on the brakes as I back down, but I DO firmly apply them for stopping.
and we DO NOT use road salt.
Wyo is offline
