RC 4.5" TC Drop Question - JeepForum.com
post #1 of 7 Old 11-07-2007, 10:00 AM Thread Starter
mizzouxj
I know I need the SYE and drive shaft for this lift but I won't be able to purchase it at the same time...is anyone running it with just a T-case drop right now and not having vibes? That's what I would do for a month or two until I could accumulate the cash for the SYE. Any input would be great.
2000 White XJ Sport | 2" Rough Country | 15x8 Eagle Alloys Series 187, 30x9.50 Dayton Timberline A/Ts | Carr Light Barr w/ 4 KC 100W 69 series | Custom Tube Bumpers from my old XJ | Complete Rockford Fosgate Sound System with Alpine Headunit
mizzouxj is offline
post #2 of 7 Old 11-07-2007, 10:05 AM
dopod
dopod's Avatar
Wait until you can afford both. Just keep saving. That lift is going to get you closer to 5-5.5" so you will run the risk of having your rear DS slip off. Plus you have the external slip yoke which is more prone to vibes (I have the same and had vibes with only 2" of lift).
dopod is offline
post #3 of 7 Old 11-07-2007, 10:06 AM
Painkiller
Guest
yeah ive been running it for almost 2 years with no vibes, i hear the older ones are less prone to vibes, the only reason im going to get one is i like how its just an all around stronger setup
Painkiller is offline
post #4 of 7 Old 11-07-2007, 11:09 AM Thread Starter
mizzouxj
My only other option is to go 3.5" RE Super Ride and take off my 2" and run the drop until I can afford the SYE and then after that put the shackles back on and get bigger front coils. I know the RE is a "better" kit as most people would say but I have never heard anything bad about RC either the only advantage to the RC is I can get a 4.5 kit for the price of the 3.5 RE sells.
mizzouxj is offline
post #5 of 7 Old 11-07-2007, 11:27 AM
Mitchell1789
1995 XJ Cherokee
Im running the RC 4.5 in kit with the tc drop that was included. Have driven down the highway 9 hours straight no vibes EVER. Been running this setup for about a year, never had vibes. Then again, I have a 95...
Got a clean xj? Want to sell it? PM me if so.
-04 5spd rubi on 35's- gone
-95 5spd XJ on 32's- Gone
Mitchell1789 is offline
post #6 of 7 Old 11-07-2007, 12:01 PM
sjbond67
i have 4" lift (rear is actually 3") and a 3/4" tc drop i get vibes. im going to install a 1.5" shackle to hopefully better the pinion angle (maybe) but i have a hack n tap, just need to get around to installing it and buying a front ds at a junkyard. i picked up my hnt off ebay for 60, plus 50 for spicer flange (actually need to order that too), and going to pull ds out of jy for 40 bucks, so for about 140 you can beat that.. unless i need to rebuild ds then it probably will be more around 200. but yea you are definatly going to have vibes with that much lift
sjbond67 is offline
post #7 of 7 Old 11-07-2007, 12:45 PM
bigbluezj94
bigbluezj94's Avatar
1994 ZJ
i have about 4 - 4 1/2 inches with a bastard pack and then another 2 with drop shackles and i have no vibes. only other mod is a new RE slip yoke. every jeep is diff! try it and see what happens. personally i think you will be fine with the tc drop
bigbluezj94 is offline
Transfercase Drop Question (liting front 3" and rear 3.5") Super6XJ XJ Cherokee Technical Forum 22 02-07-2010 05:24 PM
Transfer case drop Question- 1.5"?? MightyMouse13 XJ Cherokee Technical Forum 10 10-18-2008 01:37 AM
RC control arm drop brackets "installed" mikeypmcg XJ Cherokee Technical Forum 7 03-24-2008 05:41 PM
3" lift, 1" diff drop, stock shaft = any tips, tricks, ideas? Acostanza XJ Cherokee Technical Forum 0 04-11-2006 08:29 PM
Fresh RE 3.5" lift - Question regarding TC drop. LoricXJ XJ Cherokee Technical Forum 14 10-29-2003 03:02 PM
