Question airbag replacement - JeepForum.com
post #1 of 4 Old 01-15-2016, 06:01 AM Thread Starter
Gtrsrlly
1997 XJ Cherokee
I have a 97 4x4 Cherokee country and I was wondering if replacing both airbags is something easy or difficult, or better yet something I could do my self or not
Gtrsrlly is offline
post #2 of 4 Old 01-15-2016, 06:53 AM
JeepinInJackson
1989 XJ Cherokee
I do not recommend messing with your airbags yourself if you do not know what your doing, have you seen an air bag go off? If you decide to i would definately unhook battery and make sure all juice is discharged before messing with them.
JeepinInJackson is offline
post #3 of 4 Old 01-15-2016, 09:38 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Yes, you can replace airbags yourself, if you follow the safety precautions. I have replaced several sets of XJ Cherokee airbags on wrecks that I rebuilt. The airbag system is self testing and will not clear the airbag light if your parts are non-functional or installed incorrectly.
Send me Private Message and I can send you complete instructions.
WARNING: THE AIRBAG SYSTEM IS A SENSITIVE, COMPLEX ELECTROMECHANICAL UNIT. BEFORE ATTEMPTING TO DIAGNOSE OR SERVICE ANY AIRBAG SYSTEM OR RELATED STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENTS YOU MUST FIRST DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE. THEN WAIT TWENTY MINUTES FOR THE SYSTEM CAPACITOR TO DISCHARGE BEFORE FURTHER SYSTEM SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO DO THIS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 4 Old 01-15-2016, 03:22 PM
bluejunior
bluejunior's Avatar
Super easy, just a couple bolts BUT disconnect your battery for at least 20 minutes before you touch ANYTHING related to an airbag.
It's a simple, easy precaution but not following it can get you seriously hurt or worse.
Lifted, Locked, Stiffened
bluejunior is offline
air bag , question , replacement
