Pulling interior... removing center console? - JeepForum.com
post #1 of 6 Old 01-15-2007, 10:08 PM Thread Starter
XJ4oh
1997 XJ Cherokee
Been getting some work done on the Jeep lately, ive pulled all the seats except the drivers seat and the center console.
How do I remove the center console, does the transmission shifter handle need to come off (I assume so), aswell as the t-case handle? If so whats the best way to removing them without breaking stuff...? lol.
And what is holding down the center console itself? Bolts, clips... what?
And last, I beleive the airbag censors are under the center console on my 97 (went in for recall work to re-locate them). So for saftey reasons I think I should disconnect the battery totally to prevent any accidental deployment. Is it safe to bump the censor, or once you bump it its just gonna blow up?
Thanks... progress feels good.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #2 of 6 Old 01-15-2007, 10:36 PM
Chris_Walker
Chris_Walker's Avatar
1988 XJ Cherokee
In my 88, the shifter handles didn't need to come off. I'd assume it would be similar in a newer one. You can pull the transfer case shifter back, and when the console is unscrewed you can rotate or w/e and pull it over the transmission shift lever.
Chris_Walker is offline
post #3 of 6 Old 01-15-2007, 10:40 PM
mizzouxj
The shifter handle just simply pulls off straight up..or mine always has.
2000 White XJ Sport | 2" Rough Country | 15x8 Eagle Alloys Series 187, 30x9.50 Dayton Timberline A/Ts | Carr Light Barr w/ 4 KC 100W 69 series | Custom Tube Bumpers from my old XJ | Complete Rockford Fosgate Sound System with Alpine Headunit
mizzouxj is offline
post #4 of 6 Old 01-15-2007, 10:47 PM
JrTjK
1978 FSJ Wagoneer
pop up the bezel for the t-case shifter and tranny shifter, there is 1 screw under both, and then lift your console lid and there are 2 screws in there. aside from that, to get the transmission shifter bezel completely out, you need to pull the shifter handle off. (carefuly, i hit myself in the face!)
JrTjK is offline
post #5 of 6 Old 01-15-2007, 10:51 PM Thread Starter
XJ4oh
1997 XJ Cherokee
Thanks yall, so 4 bolts holding it on... 1 under the t-case bezel, 1 under the transmission bezel, and 2 under the console lid under the tray in there.
Doesnt sound bad at all. I just need to remove enough to pull the carpet out.
Baja Aux. Lighting.
XJ4oh is offline
post #6 of 6 Old 01-15-2007, 10:52 PM
mizzouxj
I would just take it all the way out that would end up making it a lot eaiser..its not very heavy
mizzouxj is offline
Removing the center console on a 98? Boognish015 XJ Cherokee Technical Forum 4 01-07-2008 03:07 PM
Removing the center console. Ski01xj XJ Cherokee Technical Forum 2 11-04-2007 03:07 PM
Removing the center console on a 99: How? midfat XJ Cherokee Technical Forum 5 08-28-2007 10:40 AM
removing center console..how?? iwishihad1 XJ Cherokee Technical Forum 7 11-21-2006 02:36 PM
Center Console scotty'98 XJ Cherokee Technical Forum 4 02-10-2006 06:35 AM
