Power Window Switch - JeepForum.com
post #1 of 22 Old 03-05-2007, 06:45 PM Thread Starter
JeepJinx
Power Window Switch
---deleted---
JeepJinx is offline
post #2 of 22 Old 03-05-2007, 06:52 PM
Chris_Walker
Chris_Walker's Avatar
1988 XJ Cherokee
What year Cherokee?
Chris_Walker is offline
post #3 of 22 Old 03-05-2007, 06:55 PM
Chris_Walker
1988 XJ Cherokee
If you want a brand spankin new one, and it's a 93-96, you can get it here:
http://www.teamcherokee.com/Electrical/index.html
post #4 of 22 Old 03-05-2007, 07:05 PM
MGrobe
Man In Black
MGrobe's Avatar
My power windows switch is intermitent on my passenger-side door as well. Talking to a guy on an XJ list, he has repaired a couple and generally he found that either cleaning the switch or resoldering a crack solder joint usually did the trick.
Just thought I would mention it in case you might feel inclined to rip apart the switch, prior to buying a new replacement.
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
post #5 of 22 Old 03-06-2007, 08:21 AM Thread Starter
JeepJinx
---deleted---
JeepJinx is offline
post #6 of 22 Old 03-06-2007, 09:04 AM
XJ2000
XJ2000's Avatar
You've got the same problem as I and many other owners on here have. You don't need to replace the passenger side switch, because that will basically leave you with the same problem anyway. I believe the problem starts on the driver door. I'll try to find the write up some where and post it up.
: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline
post #7 of 22 Old 03-07-2007, 07:10 AM Thread Starter
JeepJinx
---deleted---
JeepJinx is offline
post #8 of 22 Old 03-07-2007, 11:48 AM
XJ2000
XJ2000's Avatar
I haven't forgotten about it. I have been lookin for a couple days and I can't pull it up anywhere. I thought I had it saved under my favorites but I don't. I'll do a couple more searches see what comes up. I'll let you know later I gotta run out now for a little while.
XJ2000 is offline
post #9 of 22 Old 03-07-2007, 11:53 AM
TwoOne
Any chance this is what youre lookin for?
http://www.jeepinjoe.com/html/power_window_switch.html
Louis
99 WJ Limited
TwoOne is offline
post #10 of 22 Old 03-07-2007, 12:05 PM
XJK
The Guru of Nothing
XJK's Avatar
well im pretty sure every XJ owner evr has this problem
but what is going on is that the plug going into the switch is loose and will cause the passenger windows to work intermittently
*how to fix this problem*
1. there is a link with a way to bypass the child window lock which will perminatly fix the problem !but i dont know where this link is)
2. you can also hit the side of the door on the inside and it will temporarely fix it
3. or you can take apart the door panel and secure the top plug going into the window lock with tape or some adhesive, this is what i did and i havent had a problem since
-kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #11 of 22 Old 03-07-2007, 12:23 PM
MGrobe
Man In Black
MGrobe's Avatar
Originally Posted by KCMK
Strangest thing! Yesterday the switch did not work (and "yes" the power on/off switch on the driver's main panel was on)....and now this morning it's working fine. Maybe it does just need a good cleaning. Or maybe my car has gremlins
Btw, McGrobe, I like your Bushwacker pocket flares. I had those on my last TJ...loved them.
KCMK
Thanks on the BW compliment. My switch works similar to yours. Sometimes nothing, occasionally somethin. If I start it from the driverside, then usually it will work from the passengerside.
I have some work to do that involves taking the door panel off when the weather gets warmer, so I will look into the switch problem at the same time.
-Marc-
Sweet Pea 1998 - XJ
MGrobe is offline
post #12 of 22 Old 03-07-2007, 03:53 PM
XJ2000
XJ2000's Avatar
That wasn't the link I was looking for, but I guess it would work. I got back a little while ago and was looking/searching for it and still can't find it. I'm sorry.
XJ2000 is offline
post #13 of 22 Old 03-07-2007, 06:49 PM Thread Starter
JeepJinx
---deleted---
JeepJinx is offline
post #14 of 22 Old 03-07-2007, 07:48 PM
OBXJ
OBXJ's Avatar
if it happens again, try the the switches on the rear doors. This will let you know if its actually the passenger door switch or the very common drivers side window lock switch going bad. you can search my posts for the fix to the driverside window lockout switch problem.
2003 Jeep WJ Limited - Stock DD
1998 Jeep XJ - 4.0L, AX-15, Np231, Chrysler 8.25 rear, Dana 30 front, RE 4.5", 305/70R16 BFG MT's, 16" Cragar Soft 8's, OBA, Bushwacker Flares, AA SYE, CRC Custom DS, RE Gen2 Disco's, OME Nitro's, IPF H4 Headlights, Hella 500 Driving Lights, Factory Overhead Console, Surco/Yakima Roof rack, Hidden Hitch, K&N Apollo Intake, AirFlow Snorkel, AirRAID TBS, Alpine head unit with Sirius Module, sealed & hydroblocked.
OBXJ is offline
post #15 of 22 Old 03-08-2007, 12:15 AM
filluptrk
This is what I used to fix my window problems. It is 97+ Power Window Fix w/pics dated 06-30-2006. Did it and it worked great. Phil
filluptrk is offline
Master Power Window Switch. ohioviper XJ Cherokee Technical Forum 1 07-04-2009 12:59 PM
power window switch NotmyJK XJ Cherokee Technical Forum 3 01-28-2008 02:29 PM
power window switch kfcforlife XJ Cherokee Technical Forum 8 04-16-2005 08:21 AM
Power Window Switch 88XJ_WI XJ Cherokee Technical Forum 7 03-01-2005 12:33 AM
Power window switch problems TJL XJ Cherokee Technical Forum 2 09-06-2004 06:50 PM
