Power loss with 33's? - JeepForum.com
post #1 of 15 Old 05-28-2003, 01:35 PM Thread Starter
Mastaman65
Guest
Hey guys I'm just tryin to plan ahead here before I do too much too early. I'm thinking I would like to get the rusty's 6" lift and go for 33's. However recently I read that there may be some issues with power loss. If so how bad is it with the 4.0? thanks
Oh and before I forget has anyone out there used the Rusty's 6" lift kit if so how do you like it, or what have you heard, thanks again!
Mastaman65 is offline
post #2 of 15 Old 05-28-2003, 01:59 PM
rollinashortysahara
Guest
re gear and it will almost seem normal um but it costs mega $ if you don't know someone .
rollinashortysahara is offline
post #3 of 15 Old 05-28-2003, 10:10 PM Thread Starter
Mastaman65
Guest
does anyone use Rusty's at all??
post #4 of 15 Old 05-28-2003, 10:48 PM
EricsXJ
EricsXJ's Avatar
Yeah, just not his suspension products.
On the gearing issue, I can feel the loss of power when I went to 31's. You could attempt to run 32's on stock gearing but its far from ideal. 33's - I wouldn't even consider it - regear to 4.56 if you have an auto.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #5 of 15 Old 06-01-2003, 09:36 PM
wndrlst
gears
I ran 33's with 3.07's for 10 months, not good. I just put in axles with 4.11's from a junk yard Jeep. I cost me less ($225.00) to buy two axles than to regear one of my original axles. I can get into first without slipping the clutch anymore, and with 4to1 t-case gears I'm at a 62'ish:1 crawl ratio.
If you can change you can swap axles, setting up gears is another issue. Just a thought.
Doogie
'89 XJ, mildly modified
wndrlst is offline
post #6 of 15 Old 06-01-2003, 09:38 PM
wndrlst
gears
If you can change your shorts you can swap axles, setting up gears is another issue. Just a thought.
Doogie
wndrlst is offline
post #7 of 15 Old 06-01-2003, 11:08 PM
basalt51
I have the auto with 33s and 3.55s. It's still pretty peppy of the line and around town. The only real problem is on the freeway, just stick it in 3rd and it will still pull real strong and cruises at 70 mph or so @2600rpm
If you have an auto I think you can get by for however long you need to until you can afford to regear.
I'll be going to 4.56s eventually.
'97 Cherokee Country RE 5.5", 35" Goodyear MT/Rs, RRO Step-Rails, Skid-Row TC and gas tank skids, BPI bumpers, Dynatrac HP44 and Spider9/Tru Hi9 with 4.88s, Explorer discs, and detroits.
basalt51 is offline
post #8 of 15 Old 06-02-2003, 12:37 AM
Ty2003K
I was wondering about the same question since im hoping to go to 33's. I went up to 32's now at 31's because of rubbing but never felt a difference in power. I have a 4.0 high output with a 5 speed. I went from completly stock to 4 inches of lift and 32's without feeling a difference, would 33's really really be much different than the 32's?
Ty2003K is offline
post #9 of 15 Old 06-02-2003, 01:22 PM
xcmbike
xcmbike's Avatar
I felt a sure difference when i went from stock to 30's. 33's cant be good stock. I also have a 4.0 HO manual. Fork out the money and do it the rite way if your gona go to 33's.
00' Cherokee XJ. K&N Intake. 31 x 10.5 Kumho MT, 3" lift, Pre-runner bar.
Mr. December in the 2004 Jeepforum.com XJ calendar
xcmbike is offline
post #10 of 15 Old 06-02-2003, 08:36 PM
Frpyhax
Guest
With the automagic the power loss is not felt as much. So I say if you have a 5 speed your going to have to regear. With auto I would try it out, I went from stock to 31x10.50s and didn't feel any loss.
Frpyhax is offline
post #11 of 15 Old 06-02-2003, 10:01 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
I thought 4.10s were the number for 33s & auto? if you're trying to get closer to stock.... I thought 4.56 were a little steep...
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #12 of 15 Old 06-03-2003, 03:12 AM
EricsXJ
EricsXJ's Avatar
Everything I have researched so far (including talking to those who have run 4.56 with 33's) has me convinced that 4.56 is the way to go. I was even going to run 4.56 with 32's but I've decided I want to go bigger on the tires and go 33's. Honestly I think 4.11 would be perfect for 31's but thats only if you are never going to go bigger. I only want to re-gear once.
Eric
My website -
EricsXJ is offline
post #13 of 15 Old 06-03-2003, 11:52 AM
rollinashortysahara
Guest
good luck eric, i don't know what the o.d. is on an auto jeep but yeah my friends yj ( ax 15 with 35s and 4.56 gears ) that thing pulls like 2700 @ around 70 going down the interstate which seems like a little much to me but the power would be nice.
post #14 of 15 Old 06-03-2003, 04:10 PM
EricsXJ
EricsXJ's Avatar
Yeah with a manual tranny you don't need as low a gear. Stock gearing with manual tranny is usually 3.07 compared to 3.55 which is stock with an auto tranny...
Eric
My website -
EricsXJ is offline
post #15 of 15 Old 06-03-2003, 06:28 PM
greg nauman
Guest
If you are running mostly on the road with trail use now and then because your jeep is a daily driver, I would go with 4.56 if you have an auto and 4.10 if you have a stick running 33's. Then if you need more gear go to the 4.1 transfer case kit. I am running 4.10 with 33's and a 5 speed and it is great. I would like to have a 4.1 kit though someday for trail use. Only to have a better crawl ratio. Like the Rubi.
You almost never will have too low a gear for the trails but you can on the road!
greg nauman is offline
loss of power v1persrt10 XJ Cherokee Technical Forum 1 11-09-2009 07:52 AM
84 XJ Loss of Power carr51 XJ Cherokee Technical Forum 2 12-16-2006 03:51 PM
Power loss w/ 30s and 31s JayIV XJ Cherokee Technical Forum 18 11-04-2005 12:32 PM
Loss of Power in 4HI OnlyinmyJeep XJ Cherokee Technical Forum 1 07-28-2004 02:52 PM
Loss of power.. JUNIOR80 XJ Cherokee Technical Forum 10 03-03-2002 10:06 PM
