Possible Transmission Damage Help!!! - JeepForum.com
post #1 of 7 Old 02-21-2015, 04:27 PM Thread Starter
crismon
The other day I was coming back from school in my 2000 Cherokee Sport and lo and behold it starts sputtering on me so I pull off to the side of the road, shortly after it dies on me. After calling my friend for a jump and driving about 50 more feet it does so again, and so I had to tow it. Unfortunately I couldn't afford to get it towed by a company, so I towed it with a dolly front wheels up, I put the transfer case in neutral and left the tranny in park. The trip was only about 15 miles, but now i'm afraid that i've caused transmission damage from reading that it should only be flat towed. I haven't driven it since, but I have started it, How can I diagnose any transmission damage????
p.s. the culprit of it dying on me was the alternator, i've replaced it since then.
p.p.s since replacing the alternator it won't idle, it will die if the rpms drop below the 1 mark on the meter.
crismon is offline
post #2 of 7 Old 02-21-2015, 04:35 PM
skyway0018746
Towing with the t-case in natural is fine . Have you charged the battery out of the vehicle to 100% ?
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #3 of 7 Old 02-21-2015, 05:55 PM
1stockjeep
1993 XJ Cherokee
15 miles won't hurt it, 20 or more then I recommend pulling rear driveline
1stockjeep is offline
post #4 of 7 Old 02-22-2015, 11:20 AM
dzywicki
Did the battery die on you? I had this happen on mine when the alternator went. Would not idle at all until I replaced the battery.
dzywicki is offline
post #5 of 7 Old 02-22-2015, 11:26 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
This does sound like it could be a marginal battery. The failed alternator may have left you with a battery with marginal charge.
With a marginal battery, it might be strong enough to start the engine, but marginal enough to give the engine management system fits. And stalling is one of the main symptoms with this.....
Try charging the battery with a battery charger and see if that resolves it. Battery chargers are meant for charging a deeply discharged battery. Alternators are designed to "keep" the battery charged. If charging doesn't resolve this idling symptom, then have your battery "load tested" at a parts store. Load testing is the only accurate way to determine battery condition.
Good luck and keep us updated!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 7 Old 02-23-2015, 03:54 PM Thread Starter
crismon
So I went to get the battery tested today and it turns out it was bad, got a new one plopped it in and turned the key in the ignition and a heavenly purr comes to my ears, turns out it was the battery. It's idling well and when I took it for a spin I didn't notice anything that could lead me to believe there was anything wrong with the tranny. It was such a simple fix, thanks everybody for the quick responses and the helpful info, glad to be part of the forum :-).
crismon is offline
post #7 of 7 Old 02-23-2015, 05:35 PM
tjwalker
tjwalker's Avatar
Glad we could help and that you're rolling again.
Many of us like simple problems. Except CCKen. We save his knowledge base for the tough ones!
tjwalker is offline
alternator , cherokee , idle issue , tow vehicle , transmission
