Popping sound, loss of power - 95 country, 4.0 HO, automatic - with video! - JeepForum.com
post #1 of 6 Old 01-31-2017, 07:58 AM Thread Starter
Haak
1995 XJ Cherokee
Xj Popping sound, loss of power - 95 country, 4.0 HO, automatic - with video!
Hi!
**Not allowed to post link to video because I dont have enough posts. New to this forum! Hopefully I'm able to post link soon.
Been having trouble time to time with loss of power and a quite loud popping sound when driving. The popping sounds like you're popping popcorn in a kettle. Usually, when accelerating right after start up - the same symptoms occur, though in a much smaller scale. A few "pops", some loss of power, but then it sounds and runs fine during the remainder of the trip.
However, a few days ago, after going for a long drive - around 3 hours - the popping, loss of power occurred when going in 45 mph and the engine of course was warm. I had to pullover, wait, and then it got fine. This happened 3-4 times the next 30 min of the drive until I got home. The next morning the battery was flat and I had to jump start it. The battery charged right away. The car ran better that day, even though I had to stop twice because of the same symptoms as above.
What can be wrong?
- the spark plugs are new
- distributor cap and rotor is new
- battery is new
- the alternator is supposedly good
Is it something electrical? Or air intake? Injection system? Any defect valves? Positive cables touching ground?
Any suggestions and help is greatly appreciated!
- Haak
Haak is offline
post #2 of 6 Old 01-31-2017, 10:52 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Can you tell if the popping is electrical, mechanical, or combustion induced?
D3<!L!>3D
S8NNG8 is offline
post #3 of 6 Old 01-31-2017, 01:58 PM Thread Starter
Haak
1995 XJ Cherokee
I would have to say mechanical/combustion. Not like metal on metal, more of a pop. Best way to describe it is like popcorn popping. Sorry the lack of accurateness, but not quite sure..
Haak is offline
post #4 of 6 Old 02-01-2017, 01:45 AM Thread Starter
Haak
1995 XJ Cherokee
Flat battery
Today the baatery was flat and I had to user jumper cables again... Started up, seemed to charge fine again, but the intermittent power loss and popping sound was quite notable...
Haak is offline
post #5 of 6 Old 02-01-2017, 06:25 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
The loss of power could be a plugged catalytic converter. The popping is possibly pressure building behind it, eventually needing to release. This is where you could have a blown seam in your exhaust. The flat battery could be a melted wire grounding out somewhere near that blown seam.
This is a "fly by the seat of my pants" guess so don't hunt me down if I'm wrong.
Plugged cat: Go to a muffler shop and have one of the techs start it up. They can usually tell from the sound of the exhaust if it's plugged. If plugged, get a quote and do some shopping. I had one shop quote me $750. The next shop quoted me $120.
D3<!L!>3D
S8NNG8 is offline
post #6 of 6 Old 02-01-2017, 06:31 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Second guess: it could be a failing or leaking fuel injector. The popping being the dry fire caused by it not injecting fuel. Fuel leaking and pooling could be soaking a wire and possibly combusting outside the motor eventually leading to an underhood fire.
D3<!L!>3D
S8NNG8 is offline
loss of power , popping noise
