Plan on hooking up a 7 way rv and brake controller on my 99 xj - JeepForum.com
 1Likes
  • 1 Post By KF4SQB
post #1 of 5 Old 02-16-2020, 08:24 AM Thread Starter
02grandy
02grandy's Avatar
Xj Plan on hooking up a 7 way rv and brake controller on my 99 xj
Currently i have the basic 4 flat. I do see the blue wire under the front dash for the electric brake power. I need to do some more investigating for other wiring and the relays but if it has the blue wire does that mean its pre run for a factory 7 way set up? Also if i go with the factory style does this have the Aux 12 volt to charge the battery on the trailer when it's hooked up ? If I get the factory mopar wiring and 7 way plug for the back is the controller and wiring for the front mopar or aftermarket?
02grandy is offline
post #2 of 5 Old 02-17-2020, 06:22 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I don't think I've ever heard of an XJ factory wired for a 7-pin trailer plug and 12v accessory charging, as XJs aren't particularly formidable towing machines.
***Chris***
chris87xj is offline
post #3 of 5 Old 02-17-2020, 08:05 AM Thread Starter
02grandy
02grandy's Avatar
I'm not sure If the factory set up doesn't have a 12volt charging wire and just electric brakes then it won't be good for me .
02grandy is offline
post #4 of 5 Old 02-17-2020, 08:08 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I added a wire for electric brakes when I installed my 7 pin connector socket. If I needed trailer battery charging I would have pulled a wire for that too.
***Chris***
post #5 of 5 Old 02-17-2020, 09:42 AM
KF4SQB
1994 XJ Cherokee
There are indeed provisions for trailer wiring for an XJ. It was even available as a factory option. Attached are wiring diagrams from the 99 factory service manual. These are all the pages related to the trailer plug wiring. I have also included a page from the 94 FSM, as the 99 doesn't show the 7-way plug itself. The actual 7-way plug in the last image is the only thing that should be used from that image. It was included as a reference only. Cheers!
99XJTrailerWiring.JPG   99XJTrailerWiring2.JPG   99XJTrailerWiring3.JPG   99XJTrailerWiring4.JPG   99XJTrailerWiring5.JPG
chris87xj likes this.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
