Overheating problems - JeepForum.com
post #1 of 52 Old 03-05-2012, 11:45 AM Thread Starter
scubamark13
1992 XJ Cherokee
I need your help, I recently bought a 92 XJ Limited that has 97k on it. I have noticed that the engine temperature gets close if not into the red range when I am on the freeway and on a steep grade for a long period of time. Then engine temp is normal when driving around town or on flat ground. I have replaced everything under the hood that I can think of and it is still overheating. Can anyone think of anything else that could be wrong with it. I can't afford much more but I need a running vehicle. I am really hoping it isn't the head. Here is what I have installed so far.
3 row radiator from radiator barn
Hesco hi flow water pump
Hesco hi flow thermostat housing
Mr Gasket 195 tstat
upper and lower hoses
heater control valve
heater hoses
fan clutch
serpentine belt
Thanks for your help,
Mark
scubamark13 is offline
post #2 of 52 Old 03-05-2012, 12:07 PM
z06elmo
have you pressure tested your cooling system?
z06elmo is offline
post #3 of 52 Old 03-05-2012, 12:10 PM Thread Starter
scubamark13
1992 XJ Cherokee
No I have not but it isn't leaking. There isn't any coolant in the oil or oil in the coolant and the coolant is green with no strange colors to it.
post #4 of 52 Old 03-05-2012, 03:02 PM
djb383
R u running big tires? Nothing blocking air flow to the grill?
djb383 is offline
post #5 of 52 Old 03-05-2012, 03:09 PM Thread Starter
scubamark13
1992 XJ Cherokee
I am running 32s and I removed the winch first thing. The only thing left up there is the fairlead.
post #6 of 52 Old 03-05-2012, 03:22 PM
djb383
I would think 32s, steep up-hill grade and hi-way speeds must raise the temp some but not into the red with all the new cooling system stuff. Any way to verify your temp gauge? Might try removing the fairlead as well.
djb383 is offline
post #7 of 52 Old 03-05-2012, 03:27 PM
xxmikewalshxx
My was doing the exact same thing. I was just about to do the radiator when I decided to try a can of engine degreaser on the radiator as it was filthy, it fixed it. No that does not help you. I tried everything, new thermo, new rad cap, several backflushs, a bottle of Kseal in case it was a head gasket, bled every ounce of air.... Is your tranny cooler up front? After much frustration I had taken it to my local garage, he said radiator or tranny cooler.... Good luck, I know it sucks, it is my only transportation.
All Stock save for one track arm bushing, one Plenumn gasket, one Thremostat, one Magnaflow Muff, some vacum crap and roof accessories. Just added, loads of burn marks, melted plastic, tires, paint, smoke tinted glass.......
xxmikewalshxx is offline
post #8 of 52 Old 03-05-2012, 03:45 PM
SuperDave14
Working down the list on mine right now. Water pump is next
SuperDave14 is offline
post #9 of 52 Old 03-05-2012, 04:02 PM
djb383
If u do water pump, t-stat, radiator and hoses at the same time, u only have to drain/re-fill coolant once.
djb383 is offline
post #10 of 52 Old 03-05-2012, 05:06 PM Thread Starter
scubamark13
1992 XJ Cherokee
Yah I have no idea what else to do. Someone mentioned it may be the head but couldn't give me a reason why or how to check it. I would really hate to put another grand into it if it isn't going to fix the problem.
Any other ideas would be appreciated,
Mark
post #11 of 52 Old 03-05-2012, 05:24 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Confused. In your original post, it says you already replaced the water pump.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #12 of 52 Old 03-05-2012, 06:28 PM
SuperDave14
Nope not me....but it was the water pump. I have never seen anything like it. The impeller looks like a blade in a blender
post #13 of 52 Old 03-05-2012, 06:46 PM
xxmikewalshxx
The guys at the garage recomended the K seal, you could see the copper flecks in it. I'm not a big junk in the trunk guy but the thought was if the head gasket had a small leak, the stuff was supposed to seal it. It's expensive, so they said but they gave it to me. It did not hurt anything, worth a try before you pull the head(s)
post #14 of 52 Old 03-06-2012, 07:20 AM Thread Starter
scubamark13
1992 XJ Cherokee
I will try almost anything before I pull the head. I will stop at Napa on the way home and pick up some K seal. Thanks for the tip. Any other ideas are welcome.
Thanks
post #15 of 52 Old 03-06-2012, 07:59 AM
jeepster383
Thanks
I would take it to a shop and have them do a block test to check for a blown head gasket or cracked head before you put junk in the cooling system
jeepster383 is offline
Overheating problems TheAlk3mist XJ Cherokee Technical Forum 9 08-17-2010 09:46 AM
overheating problems viper75 XJ Cherokee Technical Forum 3 11-14-2009 06:04 PM
Overheating problems!! AStowe XJ Cherokee Technical Forum 10 07-11-2008 01:20 PM
overheating problems tmny277 MJ Comanche Technical Forum 5 07-21-2005 03:36 PM
I still have overheating problems, please help joshsg XJ Cherokee Technical Forum 10 08-05-2003 10:44 AM
