Open loop - JeepForum.com
post #1 of 4 Old 06-06-2020, 09:52 PM Thread Starter
Charmel459
Open loop
I have replaced , I believe, everything to do with a successful smog check and yet I still have an "open loop" issue causing a to rich mixture. I'm thinking a wiring issue maybe? Any thoughts would be appreciated. 90 xj automatic, 4.0L 4x4. 180k miles.
Charmel459 is offline
post #2 of 4 Old 06-07-2020, 08:31 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Have you been to www.cruiser54.com and completed Tips 1,3,4, and 5?
How about making sure your intake manifold bolts are snug?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 4 Old 06-20-2020, 12:16 AM Thread Starter
Charmel459
UPDATE: Open loop issue resolved. LONG story short, turned out to be, (what I suspect a bazar issue) low voltage output in a relay located under the cover of the relay cluster box under the hood on the passenger side which also houses the yellow test ports. Relay closest to the front of the car. Replaced it, had a re-smog done. No longer a gross polluter and passed with exceptionally low numbers. Very happy!!
post #4 of 4 Old 06-20-2020, 07:24 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Great. Low voltage to the oxygen sensor heater will not allow the sensor to heat up.
