Oil pump priming tool - JeepForum.com
 1Likes
post #1 of 27 Old 09-09-2021, 09:42 AM Thread Starter
OCDXJ
OCDXJ's Avatar
What can you use to prime the oil pump?
I have seen somewhere that you can make a priming tool, just can't find were I read that.
01'XJ,4.0l,AW4,NP231,D30,CHY8.25,3"IROlift,Bilstei n's,IRO OTKsteering,245/70R16,NokianRotiiva AT
OCDXJ is offline
post #2 of 27 Old 09-09-2021, 09:58 AM
jtec
jtec's Avatar
2014 JK Wrangler
Wish I could find a picture =1000 words-
oil pump primer jeep - they are @20$
old school -like me
using an old dist assy, removing the gear drive for cam, and fabricate a fitting where dist rotor would go to drive center shaft with a drill or impact tool. then with the dist installed it will drive oil pump.
I would pack the new pump - vasoline - no plugs installed and crank engine till oil pressure.
jtec is offline
post #3 of 27 Old 09-09-2021, 10:42 AM
Fourspeedman
Fourspeedman's Avatar
Originally Posted by jtec View Post
old school -like me
The old distributor is the best tool ever. I had no Jeep dizzy so I got by just using a broken screwdriver. I cut off the handle part and chucked the shaft in a 1/2" drill. Stick it down to engage the pump drive shaft and spin away.
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is offline
post #4 of 27 Old 09-10-2021, 05:49 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Crank with the CPS unplugged. You will see oil pressure rising on gauge in seconds. Plug CPS in and start the engine,
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 27 Old 09-10-2021, 10:10 AM
2oldjeeps
2oldjeeps's Avatar
8 mm socket fit my ford
99wj, 150,000 miles
00xj ,189,000 miles
10hummer3,76,000 miles
98xj, 133,000 miles
2oldjeeps is offline
post #6 of 27 Old 09-10-2021, 12:51 PM
Saudade
1988 XJ Cherokee
When I replaced my distributor, I stripped the shaft out of my old one in case I need it.
Saudade is offline
post #7 of 27 Old 09-10-2021, 03:25 PM
Fourspeedman
Lots of examples. http://mikestrawbridge.com/blog/2019...on-a-jeep-4-0/
post #8 of 27 Old 09-11-2021, 07:20 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Waste of time. Let the starter do the work for you.
post #9 of 27 Old 09-12-2021, 12:56 PM Thread Starter
OCDXJ
OCDXJ's Avatar
I took your advice to just let the starter do the work, I hooked up the mechanical gauge unplugged CPS filled with oil tried turning it over to get PSI but I get nothing.
Is there a way to get oil in the pump to create a seal so it will prime without taking everything apart?
OCDXJ is offline
post #10 of 27 Old 09-12-2021, 03:35 PM
2oldjeeps
2oldjeeps's Avatar
how long without pressure b 4 damage to bearings.
i have a reason for asking..
99wj, 150,000 miles
00xj ,189,000 miles
98xj, 133,000 miles
post #11 of 27 Old 09-12-2021, 03:49 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
None. They're under no load. They have a film of oil on them already also.
crank longer.
post #12 of 27 Old 09-12-2021, 05:27 PM Thread Starter
OCDXJ
OCDXJ's Avatar
crank longer.
I finally got it had to pull the cam poured a little oil on the driver put a drill on it and got pressure pretty quick.
The mechanical gauge was at 20PSI hot idle put the sensor back in and it only read 10PSI so gauge just sucks ***, at least I have a new oil pump in and a new gasket that doesn't leak, pressure is the same as when I started.
OCDXJ is offline
post #13 of 27 Old 09-12-2021, 07:31 PM
2oldjeeps
2oldjeeps's Avatar
crank longer.
what about cam bearings,lifter / rocker springs?
i wonder why cranking got no oil but i finally pulled dist and used a socket.
this is on a big block ford.
afterwards i cranked and got 60.
im concerned
99wj, 150,000 miles
00xj ,189,000 miles
98xj, 133,000 miles
post #14 of 27 Old 09-12-2021, 07:50 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The engine has the same amount of oil on those components as an engine that was turned off how many days his hasn't run.
Let's say you park your Jeep for a month or more. You don't need to prime the oil system before you start it.
post #15 of 27 Old 09-12-2021, 09:07 PM
2oldjeeps
2oldjeeps's Avatar
but ?my engine cranked last year with good oil but now, new oil pump was "primed" with oil b4 installed but no oil when cranked. without plugs it was spinning...
finally with a drill/socket it was fine.
?any damage when cranking with no pressure.??
appreciate you knowledge
99wj, 150,000 miles
00xj ,189,000 miles
98xj, 133,000 miles
