oil leak in airbox - JeepForum.com
post #1 of 5 Old 08-13-2019, 02:18 PM Thread Starter
91XJNamedWexler
oil leak in airbox
So I recently bought my first Jeep, a 1991 Cherokee Laredo. It has 158,000 miles and since purchasing it I’ve redone the entire cooling system, literally the first day driving it where it didn’t overheat, I noticed an oil puddle under the vehicle, it seems oil is being sucked into the airbox. I’ve read a few threads about this exact issue, but can’t really find a detailed troubleshooting list. Any and all help is appreciated. One thing to note is that I’m not entirely sure how well taken care of this Jeep was. I don’t think the owners totally trashed it, but I don’t think they were as meticulous as I would’ve been.
91XJNamedWexler is offline
post #2 of 5 Old 08-13-2019, 02:34 PM
jtec
2014 JK Wrangler
excess blow by could also be an issue bu t check the PCV (CCV) system first...
jtec is offline
post #3 of 5 Old 08-14-2019, 05:20 AM
75SV1
To understand the problem, the CCV system pull air from the airbox. If the balance of the system go out of wack the airbox pulls the air from the valve cover into it. I had this issue with my '88 Comanche. Try a new valve cover gasket. I like the molded FelPro one. Not cheap though $40. A few upgrades could help. Latter XJ's had a larger CCV Tube to the manifold. You need the fitting going into the manifold and the tube. Also, the 93-95 Grand Cherokee had an aluminum valve cover with the newer grommets, CCV port meters. Don't know if it works better or not.
75SV1 is offline
post #4 of 5 Old 08-14-2019, 10:40 AM
axlaxl
The CCV system needs to be set up right.
https://www.jeepforum.com/forum/f11/...-flow-2829394/
Here are the parts you need.
Grommets
http://www.amazon.com/gp/product/B000C5I49C/
Rear Elbow (low flow) Identical to what I pulled out
http://www.amazon.com/gp/product/B000JZI1U2/
Front Elbow (high flow)
http://www.amazon.com/gp/product/B000JZIXIW/
Amazon says it does not fit but it does.
Everything fit in nice and snug.
axlaxl is offline
post #5 of 5 Old Yesterday, 06:57 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This helps also:
CRUISER'S MOSTLY RENIX TIPS
CRUISER’S VALVE COVER MOD
NOVEMBER 17, 2015 SALAD 43 COMMENTS EDIT
Most early and even later Renix 4.0s could be bothered by excessive oil in the air cleaner box.
A fix from my old days as Service Manager at a Jeep dealership follows. Information was provided to me from a buddy at JeepTech during those days. I don’t believe it ever came out in a Technical Service Bulletin.
Remove the valve cover and turn it over. Next, remove the fluted tubes that are now facing you by removing three screws on each.
Valve cover flute
Chop 1 inch off each of them. Then, drill a half inch hole as shown in the photo. The flat side of the flute that’s closest to the edge of the valve cover. valve cover flutes (2)
Clean and de-burr/sand all rough edges nicely, clean with solvent, and reinstall. Don’t be concerned about the chintzy gaskets that will probably crumble into oblivion when you remove the fluted tubes. They can go back together without gaskets.
For photos and video, click here: http://cruiser54.com/?p=131
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
