Oil Analysis: Potassium and Sodium present. - JeepForum.com
post #1 of 9 Old 02-12-2020, 07:48 PM Thread Starter
MSH5337
MSH5337's Avatar
Does anyone send their oil off for analysis? I sent off samples from my last two oil changes, and both readings have come back with small amounts of potassium and sodium. Looks like coolant is getting in the oil. What’s strange though, is that the second sample had less amounts than the original. Any ideas why that is? How would that be improving and not getting worse?
2001 Amber Fire TJ
1989 Wagoneer Limited. 4X4
MSH5337 is offline
post #2 of 9 Old 02-12-2020, 10:43 PM
car6car
watch fluid levels and how oil looks. I wouldn't worry about anythging else.
04 Grand (dead)
car6car is offline
post #3 of 9 Old 02-13-2020, 04:35 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Does the analysis mention Ethylene Glycol, the main component of coolant ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 9 Old 02-13-2020, 05:58 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Potassium and sodium is table salt.
***Chris***
chris87xj is offline
post #5 of 9 Old 02-23-2020, 07:14 PM
KF4SQB
1994 XJ Cherokee
Close. Chlorine and sodium is table salt.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #6 of 9 Old 02-24-2020, 12:04 AM
TheBoogieman
Coronavirus survivor!
TheBoogieman's Avatar
Common metals used in oil additives are sodium, potassium, magnesium, calcium and barium. Key elements that you will want to look for are boron, chromium, phosphorus and silicon. All of these elements are associated with antifreeze and, if found in engine oil, can be an indicator that you have a coolant leak.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes. ***SOLD*** for Covid-19 pandemic rent money. :(
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #7 of 9 Old 02-24-2020, 05:09 AM
MaskedMallard
Xj
What kind of oil do you use & weight of oil?
What kind of filter?
Did you use the container you had your lunch in, to send in the oil samples?
Although, with the potassium, it's sounding like an antifreeze leak of some sorts...
2001 BJC Orvis XJ Build -
MaskedMallard is offline
post #8 of 9 Old 02-27-2020, 12:08 AM
rep-tile
rep-tile's Avatar
Why I make sure to use only oil that says gluten free on the label. They didn't find coronavirus at least.
I would rely more on how the dipstick looks or smoke coming out of the exhaust as indicator.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, Jones Exhaust A3518M-5
rep-tile is offline
post #9 of 9 Old 02-27-2020, 07:34 AM
TheBoogieman
Too late by then.
