O2 Sensor Help - JeepForum.com
post #1 of 15 Old 03-06-2013, 08:22 PM Thread Starter
StevenXJ
O2 Sensor Help
I went to recently replace the O2 sensor on my Jeep and found out that apparently the person before me used a universal or something and cut the connector for the sensor from the harness. Is there any way to replace that so I can use the NTK sensor?
StevenXJ is offline
post #2 of 15 Old 03-07-2013, 08:49 AM
CCKen
CCKen's Avatar
Here's some data from the NTK/NGK website concerning universal O2S installations. Hope it helps in your case.
http://www.ngksparkplugs.com/images/...t_11-16-04.pdf
CCKen is offline
post #3 of 15 Old 04-29-2013, 07:48 AM Thread Starter
StevenXJ
Unfortunately that did not help.
StevenXJ is offline
post #4 of 15 Old 04-29-2013, 08:24 AM
CCKen
CCKen's Avatar
I think your only hope is to get one from a junk yard or a Cherokee being boned out by owner (Craigslist).
CCKen is offline
post #5 of 15 Old 04-29-2013, 08:26 AM
Max78
1992 XJ Cherokee
The PO cut your original connector off the harness? If that's the case head down to a local junkyard with some wire cutters.
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #6 of 15 Old 04-29-2013, 08:29 AM
EvolutionXJ
EvolutionXJ's Avatar
1994 XJ Cherokee
Well that sucks. Yea head to a junkyard. Clip the connector off and if you couldnt guess what's next. Sauder that bad boy on
EvolutionXJ is offline
post #7 of 15 Old 04-29-2013, 10:50 AM Thread Starter
StevenXJ
Does anyone know the year ranges that I can cut the wires off? Or should I just get a 2000 like mine?
StevenXJ is offline
post #8 of 15 Old 04-29-2013, 10:57 AM
CCKen
CCKen's Avatar
The connectors are all the same but the wire colors differ if not a 2000. Get them from a '98 + Cherokee XJ. Just let us know what you get so the wire colors can be matched up.
Do you have two upstream O2S's and two downstream, or just one up and one down?
CCKen is offline
post #9 of 15 Old 04-29-2013, 11:10 AM Thread Starter
StevenXJ
2&2.
StevenXJ is offline
post #10 of 15 Old 05-06-2013, 11:31 PM Thread Starter
StevenXJ
I got the wiring out of an 01 Cherokee. I will be putting it in this weekend. It looks to be the same colors.
StevenXJ is offline
post #11 of 15 Old 05-12-2013, 02:08 PM Thread Starter
StevenXJ
I put the new connector on (same colors) and bought a NTK sensor and put it in. I started it up and it was still throwing the same code (P0137) I did a lot of research on it and everything is ok, so now I am stuck. Any ideas?
StevenXJ is offline
post #12 of 15 Old 05-12-2013, 03:01 PM
CCKen
CCKen's Avatar
What is okay?
CCKen is offline
post #13 of 15 Old 05-12-2013, 03:14 PM Thread Starter
StevenXJ
All the wires check ok. Sorry.
StevenXJ is offline
post #14 of 15 Old 05-13-2013, 05:31 AM
CCKen
CCKen's Avatar
Which O2S is it?
CCKen is offline
post #15 of 15 Old 05-13-2013, 11:00 AM Thread Starter
StevenXJ
Bank 1 Sensor 2.
StevenXJ is offline
