Nv3500 Manual Transmission Whine in all Gears Except 4th - JeepForum.com
post #1 of 1 Old 01-12-2017, 08:22 PM Thread Starter
Johnwazup
Xj Nv3500 Manual Transmission Whine in all Gears Except 4th
I got a tough one here. I have a 2001 Jeep Cherokee with a 5 speed transmission in it. 4x2. The transmission makes a whine that sorta sounds like a supercharger in all gears except 4th. The noise is proportional to how much power is going into the transmission. If i'm cruising, nearly nothing, but if I give it gas, the noise re-appears. Noise gets louder with RPMs as well.
I just changed out the fluid for Royal Purple Synchromax and had the throw-out bearing replaced. Noise has not changed.
My guess is maybe a counter-shaft bearing? Gears 1-3 make the most noise with 1st being the loudest. 5th also whines noticeably but is relatively quiet in comparison to the first 3.
Edit: There is no noise whining/whirring noise when engine braking.
Johnwazup
Johnwazup is offline
noise , nv3550 , transmission , whine
