NP231 Compatibility for 5-Speed Tranny - JeepForum.com
post #1 of 3 Old 05-03-2017, 06:21 PM Thread Starter
Johnwazup
I got a 01' 5 speed Cherokee I am in the process of converting into a 4x4. The 2001 Cherokee will have a nv3550 transmission put into it for the conversion.
I understand what I need and what parts are compatible for everything but the transfer case. Can I get the transfer case out of any Jeep Cherokee Transmission with a 23 spline output? Or is there a difference in input shaft lengths for autos and manual transmissions for the transfer case? Must I find a transfer case that has come out of a manual transmission? Or does it not matter? If so, can the manual transmission be the aw-15 or nv3550, or must it be out of a nv3500 5 speed?
Thanks for the help.
Johnwazup is offline
post #2 of 3 Old 05-04-2017, 05:40 AM
RLE
RLE's Avatar
I don't have specific experience for your case, but I looked this up
in the parts catalogs for 97-99 and 2001 XJs.
The input gear part number for the 4.0 for 1997-2001 is 4798-113,
whether with the automatic or with the AX15 or the NV3550.
The 2.5 gas engine and the 2.5td use other p/ns.
RLE is offline
post #3 of 3 Old 05-04-2017, 08:03 AM Thread Starter
Johnwazup
Thanks
Yup, you're right. I should have looked at part numbers. Thanks! Makes looking for a transfer case a lot easier.
Johnwazup
cherokee , compatibility , np231 , nv3550 , transfer case
