np 231 rebuild kit? - JeepForum.com
post #1 of 5 Old 12-23-2007, 09:27 PM Thread Starter
SerialKiller
2014 WK
np 231 rebuild kit?
Does anyone sell a rebuild kit for the np 231 t-case? I was thinking about picking up a used one just to have in case my current one fails. I just want to know what things should be replaced in a used t-case just to freshen it up like new?
SerialKiller is offline
post #2 of 5 Old 12-23-2007, 10:17 PM
Cruzin Illusion
Round Eyed XJ
Cruzin Illusion's Avatar
1987 XJ Cherokee
Here you go:
http://www.jbconversions.com/pages/p...ild/index.html
CRUZIN ILLUSION
BUILT NOT BOUGHT
By Cruzin Illusion Customs
View the Cruzin Illusion Rig here:
(OlllllllllllllO)
Rock Frog
CIC's Build Threads:
Cruzin Illusion is offline
post #3 of 5 Old 12-23-2007, 11:16 PM
red_01_xj
XJ Cherokee
they are a pain, but if its a spare and you take your time go for it...also you may want to consider a tera 2 low kit and sye while your at it...then you could sell it later on and make some money
2000 RED XJ
4.5" RE Super Flex, Mono Tubes, 31" BFG AT, WJ seats Front and rear, Boxed Rocker panels with Rails, Upcountry Junkyard Special, homemade front bumper, C4x4 rear bumper and swing out, low profile light bar, jks disconects, farmboy tail lights lebaron hood vents, teraflex sye, Dana 30 HP with factory 4.56 disco converted to solid shafts, with powertrax, Dana 44 with detriot true trac with 4.56 and ZJ disc brakes...and the best part is all of my major mods are used
Ebay items
red_01_xj is offline
post #4 of 5 Old 12-23-2007, 11:22 PM
Cruzin Illusion
Round Eyed XJ
1987 XJ Cherokee
The experience I have with a Tera 2Lo kits is that they are very touchy. Alls it is is a selector plate that has an addition detent before 4Lo. If it is not set up perfectly it will have a tendency to pop into neutral from the 2Lo position. Actually if you have you linkages misadjusted to you transfer case you can get your transfer case to act like it is 2Lo. That is the reason I have never recommended the 2Lo kit.
CRUZIN ILLUSION
BUILT NOT BOUGHT
(OlllllllllllllO)
Rock Frog
post #5 of 5 Old 12-24-2007, 08:22 AM
Paul_C
I got most of my parts from here. http://www.drivetrain.com/transferca...%20Model%20231
They carry plenty more than what's listed so if you need something just ask. I got the overhaul kit, a small parts kit (snap rings) and a tin rear output cover. Only bearings I replaced were the front and rear output bearings. I got them at a local bearing shop. Not a bad idea to replace the chain. Most places carry the Borg Warner for 100 or more. I got my chain here. http://cgi.ebay.com/ebaymotors/Dodge...7896QQtcZphoto
It's a Cloyes brand but it works fine.
You will need a really good set of snap ring and lock ring pliers. http://4x4trailhunters.com/article.php?id=20
Paul_C is offline
ax-15 rebuild manual & rebuild kit Ac1d XJ Cherokee Technical Forum 1 07-29-2009 11:53 PM
What do I need to rebuild my D35? Rubicon304 XJ Cherokee Technical Forum 22 07-01-2009 07:48 PM
rebuild or buy another one? 97cherokeect XJ Cherokee Technical Forum 13 12-17-2007 08:26 PM
rebuild jeep12827 XJ Cherokee Technical Forum 0 10-08-2007 08:28 PM
rebuild kit 4.0 jeepteen101 XJ Cherokee Technical Forum 5 06-28-2004 05:45 AM
