Normal oil pressure for 4.0 - JeepForum.com
post #1 of 10 Old 05-10-2007, 01:23 PM Thread Starter
rbluhm
My oil pressure on my 99 4.0 seems low it is at about 20 at idle when warm and go to about 30 or 40 when driving. When outside temps ar higher it seems to be at the lowest. What is considered normal. I here some say put heavier oil in the summer, The garage is putting 5w30 when oil is changed.
rbluhm is offline
post #2 of 10 Old 05-10-2007, 01:33 PM
drivermod
Thats plenty of oil pressure. Your fine.
drivermod is offline
post #3 of 10 Old 05-10-2007, 01:33 PM
FrumpD63
I have Mobil 1 5W 30 in my 2000 4.0 from the winter and I still get 30-40 idle and 40-55 cruisin. Swappin it out for the Mobil 1 High Mileage 10W-30 in a month or so, hoping itll remedy the steady drip i got from goin syn.
FrumpD63 is offline
post #4 of 10 Old 05-10-2007, 01:39 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Pressure sounds fine, would recommend 10w30 for summer though
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 10 Old 05-10-2007, 01:48 PM
DamianDeBe
DamianDeBe's Avatar
manual says 13 at hot idle is acceptable--that's abou where I'm at. So I think you are more that fine,
DamianDeBe is offline
post #6 of 10 Old 05-10-2007, 01:50 PM
Vaj
Guest
Sounds perfect. Use 5W30 all year round.
Vaj is offline
post #7 of 10 Old 05-10-2007, 01:56 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Somebody should sticky this topic.
88XJSport is offline
post #8 of 10 Old 05-10-2007, 02:23 PM
x99j
you got more pressure at hot idle than most. my 99 runs 22psi at hot idle. these 4.0l can take almost 6-8psi before they will knock. and i personally have known a high mileage xj that was at 10psi hot idle for years with no ill effects. so as long as the motor is taken care of you should be at 20 hot idle for years! mike
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #9 of 10 Old 05-10-2007, 03:01 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
My xj idles 38psi hot idle, 60 running
-Matt
White '94 YJ Sport
UltimatE is offline
post #10 of 10 Old 05-10-2007, 03:08 PM
basso4735
basso4735's Avatar
1997 XJ Cherokee
yeah mines at 40 idle and 60ish driving.
- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline
Normal oil pressure for 91 XJ? hiram XJ Cherokee Technical Forum 4 10-14-2008 01:30 PM
normal oil pressure bmyohn XJ Cherokee Technical Forum 11 01-20-2007 11:30 PM
Normal Oil Pressure Vaj XJ Cherokee Technical Forum 10 01-04-2006 11:26 AM
Oil Pressure, Normal Ranges? law.74 XJ Cherokee Technical Forum 11 11-14-2005 09:24 AM
Oil Pressure... What's Normal? XJ-NoDough XJ Cherokee Technical Forum 4 03-14-2004 12:01 AM
