The never ending 8.25 vs dana 35 questions - JeepForum.com
 3Likes
  • 1 Post By CJ7-Tim
  • 2 Post By CJ7-Tim
post #1 of 5 Old 09-19-2021, 05:18 PM Thread Starter
tburger88
Junior Member
tburger88's Avatar
I just got my build sheet from Jeep corporate and was shocked to see listed “Corporate 8.25 rear axle” and “3.55 rear gear ratio.” Its a 2000 Jeep XJ SE. I assume this is the Chrysler 8.25 rear axle? Below is a pic of my rear dif cover. Is there a way to tell if I have 27 vs 29 spline without removing an axle?
tburger88 is offline
post #2 of 5 Old 09-19-2021, 05:40 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Yup, Chry 8.25. The last 27 spline was mid 1996, so it should be 29 spline.
Fourspeedman likes this.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #3 of 5 Old 09-19-2021, 05:57 PM Thread Starter
tburger88
Junior Member
tburger88's Avatar
thats good news right? Weren’t the 29 spline ones stronger than dana 35s?
post #4 of 5 Old 09-19-2021, 06:51 PM
CJ7-Tim
CJ7-Tim's Avatar
The 8.25 axle housing is thicker and also larger diameter than the D35. The 27-spline axle shafts on the pre-1997 8.25 are a bit better than the D35 axle shafts, but the 29-spline 8.25 is much stronger.
Fourspeedman and Wyo like this.
CJ7-Tim is offline
post #5 of 5 Old 09-20-2021, 06:22 PM
superj
superj's Avatar
To bad we don't have 3.73 or whatever comes on the tow packages in the rear ends.
Is there a worse gear ratio than 3.55? Is there a 3.07 also?
What ever my 99 two wheel driver has is the bottom of the pile for gear ratios, I will tell you that
the xj is the only jeep left in the driveway
superj is offline
