Need recommendation : best water pump other than OEM mopar - JeepForum.com
post #1 of 8 Old 09-15-2021, 05:35 PM Thread Starter
CLASSIC2000MST
2000 jeep XJ 6 cyl 4ltr auto trans...
the murray mfg pump I bought about 20 k ago decided to start leaking like a sieve this afternoon... lucky I caught it when I did.
Looking for recommendations on best repl. have heard gates as pretty good. also wondering if I should worry about " high performance " pumps that are supposed to push more fluid and lower eng temps.
Your thoughts please
CLASSIC2000MST is offline
post #2 of 8 Old 09-15-2021, 05:38 PM
rjbruzan
I have used Napa replacements with good results.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 8 Old 09-15-2021, 06:02 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Never buy a rebuilt water pump.
NAPA premium or ACDelco Gold / Professional.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #4 of 8 Old 09-16-2021, 01:07 AM
Ralph77
I used a Napa water pump myself a couple years back.
Pretty sure it is just a rebranded Gates and does come with a lifetime warranty so.....
Ralph77 is offline
post #5 of 8 Old 09-16-2021, 07:25 AM
Wyo
Wyo's Avatar
I have used both the gates and the Delco pro
But neither has been in long enough to really tell about the life expectancy.
But this is what I do know, IF you don't have a clean system, you can 'Film'
the ceramic seal and it will leak regardless of quality.
Basically you have 2 ceramic surfaces pressed together by a spring and they are essentially
flat surfaces, if you get a film of oil or other contaminants, you create a pathway for a leak to occur.
Fourspeedman mentioned using Cascade dishwasher detergent which I have yet to try, but a really thorough flush and acid clean out is essential for success.
Now I have also been told that once filmed, its over, you cannot clean it out and get it to seal again........ I cannot confirm this aspect as I never tried, but you could Cascade the system with the old pump still in and see..... still warm enough out to get by with just water for the time being.
Wyo is offline
post #6 of 8 Old 09-16-2021, 05:52 PM
Pine_Cat
Pine_Cat's Avatar
https://flowkoolerwaterpumps.com/pro...low-water-pump
https://www.quadratec.com/products/71212_100.htm
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
post #7 of 8 Old 09-17-2021, 04:51 AM
MaskedMallard
Xj
I totally agree with Tim on this one. In fact, never buy anything "rebuilt" that is designed to move fluid.
- brake master cylinders.
- clutch master / slave cylinders.
- power steering pumps.
- a/c compressors. I know new ones can get expensive.
As for a new water pump, here is another option.
https://hesco.us/products/30803/high...5#.YURyHPmRWhA
https://hesco.us/products/30803/high...2#.YURy8fmRWhA
2001 BJC Orvis XJ Build -
MaskedMallard is offline
post #8 of 8 Old 09-17-2021, 06:22 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
If you can't afford a $90 Mopar unit, check out Walmart.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
