Need to know all about backspacing - JeepForum.com
post #1 of 7 Old 06-09-2005, 08:03 PM Thread Starter
Jeepernick
Jeepernick's Avatar
2008 XJ Cherokee
I have my lift coming and bushwakers soon after(think i will order them this weekend)
I am going to get tires when i am done trimming and lifting, but what backspacing or can i just use my stock rims?
Tires=33x10.5x15 BFG MTs
I am kinda tight on money so i need to be able to just use the stocks if i can, but if not then it may set me back and i could save up longer to get rims and tires
teach me about backspacing and what all it does and and and...
Thanks again guys
Jeepernick is offline
post #2 of 7 Old 06-09-2005, 08:47 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You will need new rims with different BS for 33's. Otherwise you'll rub the LCA's like crazy and the bushwackers will look really funny without the tires out under them.
You should probably go 4" of BS or 4.5". The 4" are MUCH easier to find. The Soft8 style wheels have the 4" you need and they generally run about $40 each.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 7 Old 06-09-2005, 08:50 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
On Back Spacing, I turned up sevarl threads on eth subject just be searching "back spacing". Basically it's the distance from the back of the wheel where it mounts to the rotor/drum to the end of the rim lip behind the rotor/drum.
Less BS locates the wheel further out of the wheel well.
93 Sport
Specs in Profile.
balloo93 is offline
post #4 of 7 Old 06-09-2005, 11:03 PM Thread Starter
Jeepernick
Jeepernick's Avatar
2008 XJ Cherokee
Ok thanks i think i will go with 4in then
post #5 of 7 Old 06-09-2005, 11:20 PM
atfrith
atfrith's Avatar
Ya you're gonna need at 4.0 or 3.75 backspacing to make those 33s look wide enough for the bushwackers. even then you said they are only 10.5" wide, so it probably won't look as good as if you had boughten 33x12.50s
90 Sport 2dr
4.0 L Straight 6
Auto Transmission (AW4)
Rusty's Air Tube and K&N Filter
Dynomax Cat-Back
Cobra 19Gtl CB Radio w/PA system
2 Cheapo Baja Driving Lights mounted on front bumper
3" Rusty Coils up front, 3.5" RE leaf springs in the rear
31" Dunlop Mud Rovers on 15x8 Cragar Soft 8's
Under 21 XJ CLUB member #9
Hondas Are Like Tampons...Every Pu**y Has One
atfrith is offline
post #6 of 7 Old 06-10-2005, 02:55 AM
twisted_ed
twisted_ed's Avatar
not to jack a thead but what about 32/11.50 bfgs? i gotta do that and i was thinking of 4" nut would 3.75 be better?
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
twisted_ed is offline
post #7 of 7 Old 06-11-2005, 04:35 AM
greenbeater
greenbeater's Avatar
1968 FSJ Wagoneer
as for the wheels you could just get lucky and find some at the yard for cheap and paint them or spend 4 times the money to get ones that are new and shiny.. depends on what you whant for looks.. just remember that if you go to the yard there are quite a few different rigs that take the same bolt pattern...(ford, dodge, jeep, and some others.)
his - 68' Wagoneer, 455 Pontiac, tons
hers - 00' XJ tail rig D44, C9.25, 4.56
ours - 01' WJ 4.0
greenbeater is offline
Backspacing??? 94HOCHEROKEE XJ Cherokee Technical Forum 3 01-11-2008 03:46 PM
what is backspacing? Tybombero XJ Cherokee Technical Forum 17 11-27-2007 10:47 PM
need help on backspacing 90XJGuy XJ Cherokee Technical Forum 10 06-24-2005 02:12 AM
Backspacing XtremeJeep XJ Cherokee Technical Forum 11 04-07-2005 01:01 PM
Backspacing fdsa4877 XJ Cherokee Technical Forum 2 03-22-2005 07:44 PM
