need 1995 XJ fuse panel diagram - JeepForum.com
post #1 of 10 Old 07-17-2010, 06:43 AM Thread Starter
shelly24
1995 XJ Cherokee
hi everyone,
my 4.0 cherokee has loadsa fuses missing! just wondering if anyone can find me a fuse panel diagram please as i have no idea which each fuse is for and how many amps they are supposed to be. thanks
shelly24 is offline
post #2 of 10 Old 07-17-2010, 11:59 AM
Holder350
Holder350's Avatar
1995 XJ Cherokee
Are you needing the diagram for the PDC or the inside box?
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 10 Old 07-18-2010, 06:39 AM Thread Starter
shelly24
1995 XJ Cherokee
the inside box under the dash
shelly24 is offline
post #4 of 10 Old 07-18-2010, 07:43 AM
Holder350
Holder350's Avatar
1995 XJ Cherokee
Sorry that its so big....had to make it big so the text would show up.
post #5 of 10 Old 07-18-2010, 11:45 AM Thread Starter
shelly24
1995 XJ Cherokee
thanks for that but it isnt that one. it is rectangular and is numbered 1-28
shelly24 is offline
post #6 of 10 Old 07-18-2010, 11:57 AM
Holder350
Holder350's Avatar
1995 XJ Cherokee
I was afraid the UK version may be different...lemme see what I can find for you
post #7 of 10 Old 07-18-2010, 12:18 PM
Holder350
Holder350's Avatar
1995 XJ Cherokee
Pages from 95xj_8wr.pdf
Thats the best I can do....no real cut and dry list, but it will tell you what fuse goes to what and tell you which ones are not used.
post #8 of 10 Old 07-19-2010, 04:08 AM Thread Starter
shelly24
1995 XJ Cherokee
thank you.
from that diagram i think ive worked the fuses out as follows:
1- power seats/tow connector
2- ?
3- washer wiper
4- a/c switch
5- Horn
6- Power doors
7- Power antenna
8- Power mirrors
9- ?
10- ?
11 - NOT USED
12- Power windows
13- Radio/Lighter/LCD Illumination
14- Heated rear window
15- NOT USED
16- NOT USED
17- NOT USED
18- ABS
19- Rear wiper
20- Dimming Relay
21- NOT USED
22- NOT USED
23- NOT USED
24- NOT USED
25- ?
26- Instrument cluster connector
Can anyone grab the cover off their own vehicle and help fill in the blanks?
thanks
shelly24 is offline
post #9 of 10 Old 07-19-2010, 01:43 PM
Holder350
Holder350's Avatar
1995 XJ Cherokee
2 Heated rear window**
9 Parking lamps
10 Headlight switch
25 The gauge cluster lamps (on the dimmer circuit)
** I know that fuse 14 also feeds it, however fuse #2 is a always on battery feed to the relay, and fuse #14 is a switched ignition feed
post #10 of 10 Old 05-21-2011, 03:18 PM
Stal1878
You chaps have helped me out greatly, just bought a '96 Cherokee and it has half the fuses missing and no manual...
Is there a list of the ampage of the fuses so I don't melt anything?
Cheers!
Stal1878 is offline
electrical issue , electrical system , fuse diagram , fuse layout , jeep xj
Need fuse panel diagram SEMPER1GUMBY XJ Cherokee Technical Forum 1 02-20-2009 08:27 PM
1998 XJ Fuse Panel Diagram? coores14 XJ Cherokee Technical Forum 2 01-22-2008 01:09 PM
Fuse panel diagram nkeever XJ Cherokee Technical Forum 5 07-02-2007 05:53 PM
fuse panel Diagram 96 XJ hansgraf XJ Cherokee Technical Forum 2 10-24-2006 05:49 PM
"00 XJ Fuse Panel Diagram Mikepags XJ Cherokee Technical Forum 4 05-30-2006 10:03 PM
