MY XJ keeps shutting off while running - JeepForum.com
post #1 of 5 Old 06-18-2009, 10:28 PM Thread Starter
Mearcliff
Guest
My '98 XJ stops running after giving it a lot of gas or after a certain amount of time. I've replaced the Oxygen sensor and the crankshaft position sensor. I've really gotten frustrated. Ive made a computer test with OD 2, no codes were found, however the computer was saying that the Catalyst monitor and the oxygen sensor monitor was INC or incompatible, after that I was checking the pressure vacuum I found a hole to the EVAP canister and I taped it with duct tape to see if the problem persisted, so I turned it on again and the engine ran for 20 min but died off again. Please help I've tried everything and I just started becoming a Jeep fan and I don't have a lot of money to go to a mechanic.
Mearcliff is offline
post #2 of 5 Old 06-18-2009, 10:55 PM
findel91
i had a teacher with the same problem.. i ended up replacing the fuel pump for her... worked fine after that.
a good tip (may be a bit obvious but i always forget this) when finding the problem.. go from smallest to largest.. ie.. terminals are tight, batteries good, alternator works, blah blah blah.
-findel91
practice safe lunch use condiments
findel91 is offline
post #3 of 5 Old 06-19-2009, 04:21 AM
blacklabel000
X2 on what findel said, start off checking the little things. sometimes i spend way too long on a job that should have taken 5 minutes. fuel filters are cheap($8) and can be done in 20min.
good luck!-nick
JustExpectEveryProblem
96' XJ: 6.5 RC lift, 35 MTRs,4.88s, 30/8.8 locked, tons of homebrew, blah blah blah...
A-TOWN 4X4
blacklabel000 is offline
post #4 of 5 Old 06-19-2009, 07:51 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by Mearcliff View Post
My '98 XJ stops running after giving it a lot of gas or after a certain amount of time......
Shut-off after a period of time suggests that one of the sensors has thermal failure, when hot it's bad, when cool it works.
Test the Throttle Position Sensor (TPS). You are looking for low voltage at the idle position and just about 5 volts at full throttle. Also, watch the meter and make sure the voltage curve is smooth with no glitches.
1997-2001 the fuel filter is inside the gas tank and is not normally replaced unless the fuel pump is replaced.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #5 of 5 Old 06-19-2009, 08:52 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The coil is another item that is subject to thermal failure. Be sure to test it also. To test sensors suffering from thermal failure you have to test them while the symptom is occuring.
xjfever is offline
engine not shutting off gregpalin XJ Cherokee Technical Forum 4 10-26-2008 08:56 AM
help keeps shutting off hippiejoe XJ Cherokee Technical Forum 3 05-28-2008 08:50 AM
Help with shutting off bgcombs XJ Cherokee Technical Forum 3 09-10-2006 09:43 AM
low idling/shutting off mws3784 XJ Cherokee Technical Forum 3 03-13-2006 08:15 PM
my jeep is shutting down ryandibbs XJ Cherokee Technical Forum 4 06-21-2004 09:44 AM
