middle of the pulley system pouring out coolant randomly - JeepForum.com
post #1 of 5 Old 10-15-2015, 04:25 PM Thread Starter
MattGoetz
Xj middle of the pulley system pouring out coolant randomly
Hey I need help so I was driving around yesterday and all was good but as soon as I pulled into my driveway the engine started pouring our water but was not overheating. So I tried to see where the leak was coming from and filled the radiator back up and started it, again it was not leaking right away but once it hit 190-200 it started pouring out coolant from the middle of the pulley system, could not see exactly where it was coming from. Does anyone know why this may be happening or whats broken??
MattGoetz is offline
post #2 of 5 Old 10-15-2015, 06:33 PM
lsmurphy
water pump
lsmurphy is offline
post #3 of 5 Old 10-15-2015, 07:32 PM
shooptube
Big Brother
shooptube's Avatar
1997 XJ Cherokee
Originally Posted by lsmurphy View Post
water pump
X2 Water pump weap hole. It's a factory made sign that your water pump pulley seal is going bad.
Originally Posted by Luke95 View Post
I am Moar low.
Build Thread:
Instagram:
shooptube is offline
post #4 of 5 Old 10-16-2015, 10:12 PM
sk8rgrl
water pump
x3
sk8rgrl is offline
post #5 of 5 Old 10-17-2015, 07:36 AM
Ciphery
Ya...the water pump is turned by a pully and when the bearings in the pump start to go they leak from a drain hole in the side of the pump housing, this way you are alerted to this happening and change the pump before it seizes and leaves you stranded in the back country.....although the therostat housing is also right above the water pump housing and are subject to corrosion. Once the thermost hits 190-200F it opens to left antifreeze circulate in the system...if the housing has a hole in it it will then spray every where..could be a heater core or rad hose too.
My sugestion is to replace both the water pump and the thermostat housing, squeeze the hoses and if you hear them creak or crunch or if the ends are cracked and weather checked replace them too.
All these things might not need replacing but they should be inspected to determine.
While you are at it replace the antifreeze with new fresh stuff as the old stuff will be full of chewed up bearing bits, rust, forgin particulates and be a bad Ph balance that supports electrolytic corrosion that will imediately start attacking your new water pump/Tstat housing etc
Ciphery is offline
