low oil pressure at idle - JeepForum.com
post #1 of 6 Old 09-25-2014, 04:43 PM Thread Starter
jeeplesjeeper
jeeplesjeeper's Avatar
It's hovers at about 10lbs at idle, what would cause this? Broken sensor? Or is this just normal? Any help would be great!
-Jake
- Big Blue-'98 XJ 6.5inch w/ 33's -R.I.P
-Current- Eep A Green'98 XJ 4.5inch w/ 33s
jeeplesjeeper is offline
post #2 of 6 Old 09-25-2014, 04:50 PM Thread Starter
jeeplesjeeper
Oil is about 2k old and it has 176 on the clock
-Jake
post #3 of 6 Old 09-25-2014, 05:09 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Always verify any suspected low oil pressure. There is a possibility that your gauge is not accurate, either because of the sending unit in the block or the gauge itself.
Many parts stores will rent you a mechanical oil pressure gauge. Very inexpensive and in an hour, you'll know for sure. Call around to the parts stores for availability.
The factory spec. for the 4.0 is 13 psi at hot idle, but I've seen many 4.0 engines run for tens of thousands of miles with 10 psi.
You don't want to be chasing your tail. Verify. Test.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 6 Old 09-25-2014, 05:21 PM Thread Starter
jeeplesjeeper
Thanks! I'll verify
-Jake
post #5 of 6 Old 09-25-2014, 07:11 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
If it is 10psi HOT then this is fine. A rule of thumb is at least 10 psi per 1,000rpm up to about 40psi.
With 176k on the clock the clearances have widened so it will not hold pressure lie it used to but you only need to get oil between the moving parts and take away the heat.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 6 Old 09-25-2014, 08:49 PM Thread Starter
jeeplesjeeper
I'm really not worried about it, just curious to be honest. I know if something goes I'll just replace it
-Jake
